ALSA Question
This board is ONLY for general feedback and discussion about Audacity 2.X.
If you require help, or think you have found a "bug", please post on the forum board relevant to your operating system.
ALSA Question
Two questions about the ALSA version of Audacity:
1. Does it record full 24-bit samples? It is my understanding that some Windows API's do not record all 24-bits but rather record 16 bits and the samples are padded with 8 bits of zeroes, and that this is a limitation of Windows' DirectSound and MME.
2. If the answer to the above question is yes, are the recorded samples "bit perfect", i.e. what comes out of the A to D converter, rather than, say, the jumble that Winows' K-Mixer outputs.
Has anyone actually tested these two things?
Thank you.
Thank you.
Re: ALSA Question
I've not tested as I don't have a 24 bit sound card, but my understanding is that Audacity will correctly record 24 bit Audio on Linux (assuming of course that the sound card and drivers are 24 bit capable).
Re: ALSA Question
I had an idea of how I could partly test 24 bit recording. Using Jack audio system I played a 24 bit track and set Audacity to record the output. The recording was identical 24 bit data, so although I can't test with a 24 bit sound card I can confirm that Audacity can correctly record 24 bit data. Jack audio system is built on top of ALSA, so I think that the only remaining question is whether the sound card and driver support 24 bit recording.
Re: ALSA Question
Robert J.H. wrote a code snippet for testing the bit format of audio in a track: http://forum.audacityteam.org/viewtopic ... 90#p191390
The code can be run in the Nyquist Prompt effect http://manual.audacityteam.org/o/man/ny ... rompt.html
Re: ALSA Question
I've done this in Windows before but not Linux. Actually you don't want to use a sound card; you want to stay entirely out of the analog domain. We're testing the capability of the software independent of the hardware.
I created a wav file with known bit patterns and wrote a program to compare the source file to the recorded file. I'll have to dust off that software; it's written in PureBasic.
I'm trying to remember how I did it in Windows. I must have had something with bit-perfect playback like foobar 2000 using WASAPI and a bit-perfect recorder going. I'm trying to remember if I used Virtual Audio Cable as my "device".
Re: ALSA Question
As I wrote a couple of post back, you can do that on Linux with Jack and the result is that Audacity is capable of bit accurate 24 bit recording.chris319 wrote:I've done this in Windows before but not Linux. Actually you don't want to use a sound card; you want to stay entirely out of the analog domain. We're testing the capability of the software independent of the hardware.
Re: ALSA Question
If you want to test a sound card and its driver you could use the optical in/out, if any.
Re: ALSA Question
I am unable to perform any 24-bit experiments owing to the inability to get Audacity/Jack/ALSA to record its own output.
Jack does seem a bit of a train wreck: weird user interface, plenty of error messages, the server seems to stop itself, etc.
This would be a snap in Windows with Virtual Audio Cable.
Re: ALSA Question
After watching a Jack configuration tutorial on YouTube, I now have to ask how Audacity can be made to record its own output.
Re: ALSA Question
The only way that I know of to enable Audacity to make a bit perfect recording of its own output is with Jack.
Jack is terrific for serious audio work, but I agree that it can be difficult to set it up initially. How easy it is to set it up all depends on what your sound system is like before you start. With a simple ALSA set-up that is fully functional it should be fairly straightforward. The more complex (or broken) the sound system is when you start, the more difficult it is likely to be. The "big" Linux distributions (Ubuntu / KUbbuntu / Open Suse ... ) can be particularly tricky. Probably the easiest Jack set-up that I've done was starting from a bare-bones ALSA only Debian (stable) installation. There are also distributions that are specifically for multi-media work that have Jack installed by default. They should work with minimum effort as most of the configuration should be done for you.
So, where are you starting from, and how much time and effort are you prepared to put into setting up your dream system?
(By the way, set up correctly, "ALSA + PulseAudio + Jack" is a killer combination that blows the socks off what can be done on Windows or Mac OS X. There's a nice example of a Linux music set-up here: http://www.youtube.com/watch?v=t91xJUos ... 6VMtzDb_lr)
