Error when recording using Zoom h4n
Please state:
Piotr
Post by Piotr » Sat Aug 10, 2013 6:57 pm
I tried to record using Zoom h4n as an audio interface.
It records properly the first track.
When I record second track there is an error.
For short periods of time there is no sound recorded.
Sound(0,066 s), no sound (0,020 s), sound(0,066 s), no sound (0,020 s)....
using Soundblaster Live all is fine.
I attached samples.
I am using:
Audacity ® 2.0.0 (Unicode)
Ubuntu 12.04
test_1track.wav
first track - ok
(55.83 KiB) Downloaded 62 times
test_2track.wav
second track - with gaps
(40.31 KiB) Downloaded 68 times
Piotr
Re: Error when recording using Zoom h4n
Post by Piotr » Sat Aug 10, 2013 10:59 pm
I installed Pulse Audio, now recording doesn’t work at all in Audacity.
I checked it works well under Ardour (JACK Audio)
Post by steve » Sun Aug 11, 2013 11:32 am
Piotr wrote:Ubuntu 12.04...
PulseAudio is installed in Ubuntu by default :?
Piotr wrote:I checked it works well under Ardour (JACK Audio)
Have you tried recording in Audacity with Jack?
(Note there is a bug in Audacity - When using Jack, do not activate the recording meter before Audacity has been put into Record mode at least once, otherwise Audacity is likely to crash).
To use Audacity with Jack, start Jack before you launch Audacity. Then select "Jack audio system" as the "host" in the device toolbar.
