DMG Not Recognized[SOLVED]
Cowboy Doug
When I download Audacity 2.03 to my Mac Pro running 10.6.4 and attempt to open the download folder, I receive this message: "audacity-macosx-ub-2.0.3.dmg not recognized. What happened, or didn't happen, as the case might be?
Re: Not Recognized
OK, you skipped a few steps in there.
The download seemed to work OK. You opened up Downloads and the disk image file (.dmg) was there. You dragged it onto your desktop and tried to double-click open it? What happens if you Control-Click it > Get INFO?
Cowboy Doug
Re: Not Recognized
Thanks for the quick reply. Bear with me on this if you would please. I just bought the Mac Pro after using a G5 for years so a lot of this is brand new to me. I did exactly as you prescribed and it opened the Get Info. But what is my next step? Look forward to your reply. Cowboy Doug
- Quality Assurance
Re: Not Recognized
All that should be needed is:
If the download is corrupted, clear the download list in your web browser or download manager and try downloading it again.
- Double-click the downloaded .DMG to mount it
- Then to install Audacity, copy the "Audacity" folder from the newly mounted .DMG to /Applications or any other location of your choosing.
- Launch Audacity from the /Applications/Audacity folder you chose in step 2. Don't launch Audacity from the .DMG.
Cowboy Doug
RE: DMG Not Recognized[SOLVED]
Gale:
We are up and running.
I've been a user of Audacity for years and just love it.
Thank you every so much.
Doug
Doug
