vst effects plugins management
This read-only archive contains discussions from the Adding Feature forum.
New feature request may be posted to the Adding Feature forum.
Technical support is available via the Help forum.
willard cottrell
Post by willard cottrell » Fri Aug 02, 2013 5:20 pm
Is there a way to condense or remove the VST effects plugins you'd never use? This would be short of removing them the plugin directory?
Re: vst effects plugins management
Post by Gale Andrews » Fri Aug 02, 2013 9:13 pm
willard cottrell wrote:Is there a way to condense or remove the VST effects plugins you'd never use? This would be short of removing them the plugin directory?
Not in the Audacity interface - do you want to vote for that?
All you can do (while Audacity is closed) is to edit the plugins.cfg file in the Audacity folder for application data. See here for where it is http://manual.audacityteam.org/o/man/pr ... tml#stored . If you remove a plug-in from the list, all the plug-ins further down the list need to be renumbered.
waxcylinder
Post by waxcylinder » Mon Sep 02, 2013 4:16 pm
And once again from the same poster - answer came there none ....
Post by Gale Andrews » Mon Sep 02, 2013 10:38 pm
2.0.4 (release candidate test version is here ) will have a new dialogue where you can select the VST plug-ins to load.
The dialogue appears the first time you use Audacity, or if you reset preferences, or if you request a VST rescan in Effects Preferences and restart Audacity. So there is no need to edit plugins.cfg now.
It's still a feature request to access and edit the list of plug-ins directly in the Preferences.
