A glitch of sorts with automatic sample rate reduction.
Feedback and Reviews for Audacity 2.x
This board is ONLY for general feedback and discussion about Audacity 2.X.
If you require help, or think you have found a "bug", please post on the forum board relevant to your operating system.
KlarkKentThe3rd
Post by KlarkKentThe3rd » Tue Jul 30, 2013 1:28 am
Let's just say I imported a 48,000kHz file or higher into the program, or just raised the sample rate of a project. I then decide that I will need a dither for the export, and choose one. After I choose the dither, the sample rate will always automatically go down to 44,100. I did not ask for this, and it is definitely a glitch. This must be fixed in the next version.
I am using version 2.0.3.
Re: A glitch of sorts with automatic sample rate reduction.
Post by steve » Tue Jul 30, 2013 2:00 am
I'm guessing that when you go to "Preferences > Quality" and change the dither option, that the "Default Sample Rate" option is set to 44100.
When you then click "OK", the "Quality" settings that are selected in "Preferences > Quality" are applied.
Post by Gale Andrews » Wed Jul 31, 2013 12:57 am
steve wrote:I'm guessing that when you go to "Preferences > Quality" and change the dither option, that the "Default Sample Rate" option is set to 44100.
That's a difficult behaviour choice for us to make, if that was the problem.
We got lots of complaints when OK'ing a change in Default Sample Rate did not modify the project rate until a new project window was opened.
