A Copy Of L.A.M.E.
This board is ONLY for general feedback and discussion about Audacity 2.X.
If you require help, or think you have found a "bug", please post on the forum board relevant to your operating system.
dadabujontomasteel
- Probationer
A Copy Of L.A.M.E.
how do you get the copy of L.A.M.E.? Will it cost you anything? The reason i'm asking is because I need to convert to mp3 wav ogg etc. Please let me no if you have a solution to this problem.
Re: A Copy Of L.A.M.E.
http://audacityteam.org/download/how do you get the copy of L.A.M.E.?
The same place you got Audacity.
You should get the lame that matches Audacity and not get it from some other supplier.
I believe both lame and FFMpeg are available as stand-alone programs. You don't have to use the ones associated with Audacity. If you elect to use the stand-alone versions, you need to be conversant in command-line. I don't think they have graphics.
http://ffmpeg.org/index.html
