edit
Help for Audacity on macOS.
atomottokar
edit
Post by atomottokar » Wed Jul 24, 2013 8:59 pm
hello
how to select a small portions
ex snap portions bet 0.20 and 0.30
thanks
bonjour
comment selectionner une petite partie
ex " snapshot " portions entre 0.20 et 0.30
merci
Screen Shot 2013-07-24 at 10.38.09 PM.png (32.16 KiB) Viewed 433 times
Re: edit
Post by kozikowski » Wed Jul 24, 2013 9:02 pm
Click on the blue waves under the 0.2 mark and drag until you get to 0.3? You can get increased accuracy by magnifying the waves like it looks like you did already. If you need surgical accuracy, you can use the Start and End windows at the bottom of the Audacity screen.
Re: edit
Post by steve » Wed Jul 24, 2013 9:13 pm
...and ensure that "Snap To" is off http://manual.audacityteam.org/o/man/se ... .html#snap
