Different speeds on different computers
arabtomten
Post by arabtomten » Sat Jul 20, 2013 7:57 pm
I am recording a podcast with two Podcaster microphones using two different computers, one for each member of the podcast.When I later try to edit them together and sync them up, normally with a clap in the beginning. But there is a slight difference in the speed of the audio, so after an hour there's a noticable delay on one of the tracks. Both of the computers record at 44100 hz, with the same microphone, with the same program, so it really doesn't make any sense. I could just sync it up with another clap at the end, but sometimes, the speed changes in the middle, so i have to split the audio every ten minutes just be sure. I.e, if I sync the first clap on both of them, and then change the speed of one of them so that the second clap at the end are synced up, but still, in the middle, there is a very noticable delay. I don't know if there is something wrong with one of my computers/copies of the program, but this is getting to be very annoying without any logical reason. I really need help. Both of the computers use Windows 7 Home Premium, and as far as I can tell, it's the same version of the program. If this problem can be caused by different versions of the program, I will get to fixing it.
Re: Different speeds on different computers
Post by kozikowski » Sat Jul 20, 2013 10:11 pm
With different computer clock systems making the 44100Hz. Most clock signals just have to be accurate enough to keep the system or computer from crashing.
There is a provision on some computers to record from two different USB microphones at the same time. They warn you that the computer will use only one of the two data signals as "sync" and the other one will drift over the course of the show.
Pay attention to the direction. If one show is consistently early, that could mean that computer is dropping samples creating a gradually off-time signal. This is common on an underpowered computer, or one that is having trouble managing Skype and Audacity at the same time.
This error usually happens the first time the analog voice gets digitized. That's the first time you need to make 44100 and that's the clock signal that gets used in that portion of the show. If it's your Windows sound card, well, none of those will be winning any awards for quality. Two identical USB microphones should do quite well.
The grownups use master sync signals or expensive dual clock generators and they can go all day with no noticeable sync problems. The movie people have to do that.
By the way, congratulations on covering all the bases (except possibly one). That is exactly how I would do it if I had to marry two different sound files. How are you getting one set of human hands to appear on both computers -- assuming they're in two different locations.
Post by kozikowski » Sat Jul 20, 2013 10:18 pm
You didn't get into details about how you're recording these shows, but one thing I might do is record a clock ticking for some time (20 minutes??) with the show configuration up and running, then do it again with nothing else running except Audacity. If your clicks don't match after 20 minutes then your computer system is "doing something naughty" to the capture when it's busy.
If you have provision for bi-directional audio, then send the same clock ticks to both machines. Compare the sound files playback to the actual clock. If they both drift all over the place, you may have two "broken" computers.
Lucky you.
Post by kozikowski » Sat Jul 20, 2013 10:20 pm
Oh, and Audacity doesn't do anything to the sound during recording. Whatever the computer provides is what Audacity records. Koz
arabtomten
Post by arabtomten » Fri Jul 26, 2013 8:23 am
All right, so for my understanding. There is absolutely nothing I can do to make sure they record at the same speed? I'm guessing boosting its priority in task manager won't do anything either? I use two computers at the same location (at the time being) to record, but for what you're telling me, not even if i managed to record both on the same computer would i be able to make sure the timing will be the same? That really, really sucks. :(
DVDdoug
Forum Crew
Post by DVDdoug » Fri Jul 26, 2013 5:04 pm
If you are using the same computer and the same device (both sides of a stereo soundcard or a multi-tracking interface) it will stay in sync. However, if you use a USB mic and your soundcard, the clocks may not be identical. (No two clocks are ever identical, but they can be very close.) Higher-end interfaces should have more accurate clocks than a typical consumer soundcard. Pro equipment uses a master clock to keep all devices in sync.
Post by steve » Fri Jul 26, 2013 5:10 pm
arabtomten wrote:Podcaster microphones
That's "Rode Podcaster USB" is it?
arabtomten wrote: after an hour there's a noticable delay on one of the tracks.
How "noticeable" are you talking about? 30 seconds? 30 milliseconds?
arabtomten wrote:not even if i managed to record both on the same computer would i be able to make sure the timing will be the same?
I don't think that anyone has said that, yet.
The guaranteed way to ensure synchronisation is to throw lots of money at the problem. Depending on how severe the problem is it may be possible to improve the situation without burning a hole in your wallet.
Post by kozikowski » Sat Jul 27, 2013 5:22 am
You apparently haven't done any of the tests yet. You may find that one or both of the computers is broken and damaging the signal. Then there is certainly something you can do. Fix the computers.
You also didn't respond to the amount of error. If it's seconds off, you have a broken system.
We're telling you to do these things for a reason.
arabtomten
Post by arabtomten » Mon Jul 29, 2013 8:01 am
Oh, sorry. The delay differs from time to time. It seems to be more severe now than it was when I did the first couple of episodes, and now I've done about 10. Usually there is only a few dussin milliseconds, and in the beginning it was an easy fix. But in the later episodes, the timing seems to change during the file. I.e, if I fix the delay at the end, in the middle there is still a delay. And yes, it is the Rode USB podcaster mic.
If you don't mind me asking again, fixing it so that I can record both of them on the same computer will make it better but not completely fix it? How so? Will there be a constant delay, or will there still be two different speeds. From what I understood from the initial response, plugging them into the same computer wont fix it because it still only goes after the timing on one of the mics. Is it worth trying that, anyway?
Post by steve » Mon Jul 29, 2013 12:54 pm
arabtomten wrote:Oh, sorry. The delay differs from time to time. It seems to be more severe now than it was when I did the first couple of episodes, and now I've done about 10. Usually there is only a few dussin milliseconds, and in the beginning it was an easy fix. But in the later episodes, the timing seems to change during the file. I.e, if I fix the delay at the end, in the middle there is still a delay. And yes, it is the Rode USB podcaster mic.
Trying to understand your reply.
Are you saying that amount of de-synchronisation is a few milliseconds?
If the drift is much more than a few milliseconds then one or both devices may be broken.
Because the devices are independently "free wheeling" with no master clock signal, it is to be expected that they will gradually drift a little out of synch with each other, just like if two people that cannot hear each other start counting seconds will gradually drift apart, whereas if two people are looking at the second hand of the same clock and then start counting seconds they will be able to remain synchronised.
We need to know if they are drifting "a little" out of synch or "a lot" out of synch.
1 millisecond drift over a 1 minute period is less than 0.002 % drift, so that would be considered "a little" for a consumer level device, but quite a lot for a professional level device. Rode USB podcaster microphones are quite good consumer level devices so I'd not expect much more than a couple of milliseconds drift per minute (though of course the two devices may drift in opposite directions, effectively doubling the "error").
