problem importing audio with unicode filename
jacken
Post by jacken » Sat Nov 22, 2008 6:33 pm
I'm running Audacity 1.3.6 on a XP sp3 machine. When importing audio with unicode filename, Audacity will crash and close. No problem with 1.3.5. Any idea? Thanks.
Re: problem importing audio with unicode filename
Post by steve » Mon Nov 24, 2008 8:41 pm
Are you sure that you installed the unicode version?
You should be using the "Windows 2000/XP/Vista: Audacity 1.3.6 installer (.exe file, 4.1 MB)" version from this page: http://audacityteam.org/download/beta_windows
jacken
Post by jacken » Sun Nov 30, 2008 4:16 am
Yup. It was version 1.3.6. It has the word unicode on the About screen.
