Laptops amd mp3's
Feedback and Reviews for Audacity 2.x
This board is ONLY for general feedback and discussion about Audacity 2.X.
If you require help, or think you have found a "bug", please post on the forum board relevant to your operating system.
coolhandjjl
Laptops amd mp3's
Post by coolhandjjl » Thu Jul 04, 2013 7:37 pm
Can this software be used just for playing mp3's on a laptop? I was looking for a step up in quality from iTunes. I downloaded Decibel by S Booth, but it has no EQ or tone shaping features.
Re: Laptops amd mp3's
Post by steve » Fri Jul 05, 2013 12:53 am
You "could" use Audacity to play back MP3s on a laptop, but Audacity is designed for editing audio, not as an audio player. It would be a bit like using a combine harvester for transport.
What's wrong with using iTunes?
What operating system are you using?
coolhandjjl
Post by coolhandjjl » Fri Jul 05, 2013 1:33 am
People say there are better music player software options like Bit Perfect, Amarra, Decibel, Pure Music, Audinvanna, and this software came up in a search.
Post by steve » Fri Jul 05, 2013 1:42 am
In terms of sound quality, the hardware makes much more difference than the software. If you are playing high quality recordings in a lossless format, then the software is unlikely to make any difference to the sound quality at all.
Post by steve » Fri Jul 05, 2013 1:47 am
coolhandjjl wrote:People say there are better music player software options
It depends on what you mean by "better".
In terms of sound quality there is unlikely to be any difference. However, as a music player I think that iTunes is a massively bloated, inefficient, nasty beast, (but that's just my opinion). On Windows my preferred audio player is Foobar2000. On Linux my preferred player is DeaDBeeF.
coolhandjjl
Post by coolhandjjl » Fri Jul 05, 2013 1:51 am
I am on OSX10.8. I haven't bought a DAC yet, I was considering JDS Labs ODAC.
Post by kozikowski » Fri Jul 05, 2013 3:59 am
Itunes runs on top of QuickTime Services and QuickTime comes with a "real" Fraunhofer-Gesellschaft MP3 license. This is the group that designed MP3. Anything you do after that is up to the hardware.
The Headphone Out of a Mac is not terrible. I use mine for testing other audio equipment. It's not a second-thought add-on for Skype like on some Windows machines.
coolhandjjl
Post by coolhandjjl » Fri Jul 05, 2013 8:18 pm
kozikowski wrote:Itunes runs on top of QuickTime Services and QuickTime comes with a "real" Fraunhofer-Gesellschaft MP3 license. This is the group that designed MP3. Anything you do after that is up to the hardware.
I am using a Behringer UCA202 USB DAC I bought a few years ago for $30 because someone said "you gotta use one of these". I don't know if it makes it better or not, A & B testing is very difficult in audio.
Anyway, I opened my laptops AudioMIDI panel and it indicated to me that the cheapo Behringer thingy with my is only 16 bit. The headphone out is 24 bit. Go figure. I'll be using iTunes via the headphone out, and put the JDS Labs USB ODAC on my short list.
Post by kozikowski » Sat Jul 06, 2013 12:27 am
The UCA202 has talents way above just playing a tune into a line connection. In many instances, it's the only way to get stereo line-level into your computer. This may be the case for you if you have a modern Mac.
It also allows "out of computer" monitoring of the sound in headphones without listening to the overdubbing transition delays. Note where the headphones are plugged:
http://www.kozco.com/tech/audacity/pix/ ... Lenovo.jpg
Even on a Mac you need something like this to get Perfect Overdubbing.
The UCA202 is not a gift from the gods, but it serves something like 80% of people who post trying to get reasonable sound in and out of their computer. That's what prompted the recommendation.
If your requirements are above that, and you can throw the bux, then go for it. We are talking ten times the price.
It would be interesting if you can run both at once -- or mount both, but not run both.
coolhandjjl
Post by coolhandjjl » Sat Jul 06, 2013 2:14 am
I think the headphone output on my MacBook Pro puts out in the neighborhood of 2v. Most of the DACs out there put out a similar voltage.
