PerseP
Post
by PerseP » Sat Nov 29, 2008 9:48 pm
it's still incompatible. I did notice that the new dbghelp.dll is much smaller the the first one you gave us. Here is the log:
Code: Select all
20:09:12: Trying to load FFmpeg libraries
20:09:13: mLibAVFormatPath is not empty, = C:Archivos de programaAudacity 1.3 Betaavformat-52.dll. Loading from it.
20:09:13: Looking up PATH...
20:09:13: PATH = C:WINDOWS;C:WINDOWSCOMMAND
20:09:13: Checking that C:Archivos de programaAudacity 1.3 Beta is in PATH...
20:09:13: not in PATH!
20:09:13: Appending ;C:Archivos de programaAudacity 1.3 Beta ...
20:09:13: Loading avformat from C:Archivos de programaAudacity 1.3 Betaavformat-52.dll
20:09:14: avformat loaded successfully. Acquiring the list of modules.
20:09:14: Error: Couldn't find symbol 'SymFromAddr' in a dynamic library (error 127: no se encontró el proceso especificado.)
20:09:14: List acquired and consists of 0 modules
20:09:14: The avformat library happened to be statically linked
20:09:14: Returning PATH to normal...
20:09:14: Importing symbols...
20:09:14: Error: Couldn't find symbol 'avcodec_init' in a dynamic library (error 127: no se encontró el proceso especificado.)
20:09:14: Failed to load symbol avcodec_init
20:09:14: Trying to load from PATH. File name is avformat-52.dll
20:09:14: Looking up PATH...
20:09:14: PATH = C:WINDOWS;C:WINDOWSCOMMAND
20:09:14: Checking that is in PATH...
20:09:14: in PATH.
20:09:14: Loading avformat from avformat-52.dll
20:09:19: Looking for FFmpeg libraries...
20:09:19: mLibAVFormatPath is not empty, = avformat-52.dll
20:09:46: User-specified path = C:Archivos de programaAudacity 1.3 Betaavformat-52.dll
20:09:46: User-specified file exists. Success.
20:09:46: Trying to load FFmpeg libraries
20:09:46: mLibAVFormatPath is not empty, = C:Archivos de programaAudacity 1.3 Betaavformat-52.dll. Loading from it.
20:09:46: Looking up PATH...
20:09:46: PATH = C:WINDOWS;C:WINDOWSCOMMAND
20:09:46: Checking that C:Archivos de programaAudacity 1.3 Beta is in PATH...
20:09:46: not in PATH!
20:09:46: Appending ;C:Archivos de programaAudacity 1.3 Beta ...
20:09:46: Loading avformat from C:Archivos de programaAudacity 1.3 Betaavformat-52.dll
20:09:46: avformat loaded successfully. Acquiring the list of modules.
20:09:46: List acquired and consists of 0 modules
20:09:46: The avformat library happened to be statically linked
20:09:46: Returning PATH to normal...
20:09:46: Importing symbols...
20:09:46: Error: Couldn't find symbol 'avcodec_init' in a dynamic library (error 127: no se encontró el proceso especificado.)
20:09:46: Failed to load symbol avcodec_init
20:09:46: Trying to load from PATH. File name is avformat-52.dll
20:09:46: Checking that is in PATH...
20:09:46: in PATH.
20:09:46: Loading avformat from avformat-52.dll
- Quality Assurance
Post
by Gale Andrews » Tue Dec 02, 2008 5:02 pm
PerseP wrote:it's still incompatible. I did notice that the new dbghelp.dll is much smaller the the first one you gave us.
We've made some changes to the checking routine in the code. The build is here:
http://www.gaclrecords.org.uk/audacity- ... -alpha.zip
If FFmpeg still does not load for anyone, please post the output from Help > Show Log... and say what version of Windows you are on.
Thanks
PerseP
Post
by PerseP » Thu Dec 04, 2008 9:39 pm
it works with the 1.3.7 alpha version. here is the log if you want to check.
Code: Select all
20:48:23: Trying to load FFmpeg libraries
20:48:23: mLibAVFormatPath is not empty, = C:Archivos de programaAudacity 1.3 Betaavformat-52.dll. Loading from it.
20:48:23: Looking up PATH...
20:48:23: PATH = C:WINDOWS;C:WINDOWSCOMMAND
20:48:23: Checking that C:Archivos de programaAudacity 1.3 Beta is in PATH...
20:48:23: not in PATH!
20:48:23: Appending ;C:Archivos de programaAudacity 1.3 Beta ...
20:48:23: Loading avformat from C:Archivos de programaAudacity 1.3 Betaavformat-52.dll
20:48:24: avformat loaded successfully. Acquiring the list of modules.
20:48:24: Error: Couldn't find symbol 'SymFromAddr' in a dynamic library (error 127: no se encontrÛ el proceso especificado.)
20:48:24: List acquired and consists of 0 modules
20:48:24: Can't get a list of modules (list is empty)
20:48:24: Trying to load avcodec and avutil
20:48:24: Loading avcodec from C:Archivos de programaAudacity 1.3 Betaavcodec-52.dll
20:48:25: Loading avutil from C:Archivos de programaAudacity 1.3 Betaavutil-49.dll
20:48:25: Returning PATH to normal...
20:48:25: Importing symbols...
20:48:25: All symbols loaded successfully. Initializing the library.
20:48:25: Retrieving library version.
20:48:25: AVCodec version 0x340000 - 52.0.0 (built against 0x340000 - 52.0.0)
20:48:25: AVFormat version 0x341601 - 52.22.1 (built against 0x341601 - 52.22.1)
20:48:25: AVUtil version 0x310c00 - 49.12.0 (built against 0x310b00 - 49.11.0)
20:48:25: AVCodec version mismatch is 0
20:48:25: AVFormat version mismatch is 0
20:48:25: AVUtil version mismatch is 0
20:48:25: Libraries loaded successfully!
20:48:29: Looking for FFmpeg libraries...
20:48:29: mLibAVFormatPath is not empty, = C:Archivos de programaAudacity 1.3 Betaavformat-52.dll
20:48:57: User-specified path = C:WINDOWSEscritorioaudacity-win-1.3.7-alphaavformat-52.dll
20:48:57: User-specified file exists. Success.
20:48:57: Trying to load FFmpeg libraries
20:48:57: mLibAVFormatPath is not empty, = C:WINDOWSEscritorioaudacity-win-1.3.7-alphaavformat-52.dll. Loading from it.
20:48:57: Looking up PATH...
20:48:57: PATH = C:WINDOWS;C:WINDOWSCOMMAND
20:48:57: Checking that C:WINDOWSEscritorioaudacity-win-1.3.7-alpha is in PATH...
20:48:57: not in PATH!
20:48:57: Appending ;C:WINDOWSEscritorioaudacity-win-1.3.7-alpha ...
20:48:57: Loading avformat from C:WINDOWSEscritorioaudacity-win-1.3.7-alphaavformat-52.dll
20:48:58: avformat loaded successfully. Acquiring the list of modules.
20:48:58: List acquired and consists of 0 modules
20:48:58: Can't get a list of modules (list is empty)
20:48:58: Trying to load avcodec and avutil
20:48:58: Loading avcodec from C:WINDOWSEscritorioaudacity-win-1.3.7-alphaavcodec-52.dll
20:48:58: Loading avutil from C:WINDOWSEscritorioaudacity-win-1.3.7-alphaavutil-49.dll
20:48:58: Returning PATH to normal...
20:48:58: Importing symbols...
20:48:58: All symbols loaded successfully. Initializing the library.
20:48:58: Retrieving library version.
20:48:58: AVCodec version 0x340000 - 52.0.0 (built against 0x340000 - 52.0.0)
20:48:58: AVFormat version 0x341601 - 52.22.1 (built against 0x341601 - 52.22.1)
20:48:58: AVUtil version 0x310c00 - 49.12.0 (built against 0x310b00 - 49.11.0)
20:48:58: AVCodec version mismatch is 0
20:48:58: AVFormat version mismatch is 0
20:48:58: AVUtil version mismatch is 0
20:48:58: Libraries loaded successfully!
AlanHK
Post
by AlanHK » Thu Jan 29, 2009 6:33 am
ffmpeg export works under Win2k with 1.3.7!
Thanks.
dimensionalrealms
Post
by dimensionalrealms » Fri Apr 01, 2011 4:39 pm
I have tried many things to get this to work, nothing has yet. I Vista U. first used "audacity-win-1.2.6", this version doesn't ask for the FFmpeg library, then I installed the "Audacity 1.3.4 (Beta)" which did ask for both. I got the "Lame" to be found automaticly, the FFmpeg was not. I downloaded both exe and zip neither worked, place file in in serveral places including in programs "FFmpeg & Audacity" (not at the same time). I keep getting "Failed to find compatible FFmpeg libraries" no matter where I point to!!?
So whats the deal? I see all these questions for older operating systems has this problem not been fixed?
- Site Admin
Post
by steve » Fri Apr 01, 2011 5:10 pm
dimensionalrealms wrote:I Vista U. first used "audacity-win-1.2.6", this version doesn't ask for the FFmpeg library,
Audacity 1.2.6 cannot use FFmpeg, so it is limited to WAV, AIFF, FLAC, OGG and MP3 formats only.
Also, Audacity 1.2.6 is not recommended for Vista as it has multiple known problems on modern computers.
dimensionalrealms wrote:then I installed the "Audacity 1.3.4 (Beta)"
Audacity 1.3.4 is obsolete.
You can download the current version of Audacity 1.3 from here:
The current version of FFmpeg is available here:
http://manual.audacityteam.org/index.ph ... tallffmpeg
The current version of Lame is available here:
http://audacityteam.org/help/faq?s=install&i=lame-mp3
