Focusrite Saphire 14. Can't select correct input
Help for Audacity on macOS.
Pobinr
Re: Focusrite Saphire 14. Can't select correct input
Post by Pobinr » Fri Jul 05, 2013 7:23 am
Thanks for that lot.... Or buy Logic!
I want to play guitar, not spend hours on techie work rounds.
Thanks all the same.
Post by steve » Fri Jul 05, 2013 9:45 am
Pobinr wrote:Thanks for that lot.... Or buy Logic!
or buy a USB interface where you can use inputs 1 and 2.
Pobinr
Post by Pobinr » Fri Jul 05, 2013 4:55 pm
Do the Focusrite Scarlet USB output SPDIF on 1 & 2 ?
Pobinr
Post by Pobinr » Sat Jul 06, 2013 4:26 pm
The other niggle is in addition to deleting tracks 1-4 each time I have to make track 5 left & 6 right to make them stereo.
Pobinr
Post by Pobinr » Tue Jul 23, 2013 9:34 pm
I found I can select inputs 1 & 2 to connect to 5 & 6 S/PDIF outputs of my Saphire sound card with garage band. Works fine. But I miss Audacity. I like the layout, display & functionality of Audacity.
Maybe one day rerouting of inputs will be made possible. Keep up the good work developers.
Post by steve » Tue Jul 23, 2013 11:30 pm
Pobinr wrote:The other niggle is in addition to deleting tracks 1-4 each time I have to make track 5 left & 6 right to make them stereo.
You can join tracks 5 and 6 to make a stereo pair by opening the track drop down menu from track 5 and select "Make Stereo track" (no need to set the channels - track 5 will automatically become left and 6 will become right).
Pobinr
Post by Pobinr » Fri Aug 02, 2013 7:01 pm
I hope one day it's possible with Audacity to remap inputs. It's much nicer to use than garage band.
Post by Gale Andrews » Fri Aug 02, 2013 9:22 pm
Pobinr wrote:I hope one day it's possible with Audacity to remap inputs. It's much nicer to use than garage band.
Thanks. Your vote has already been counted but I do suggest you post in http://forum.audacityteam.org/viewtopic ... 61#p206661 encouraging the developer to resume the work he had started.
Pobinr
Post by Pobinr » Sat Nov 16, 2013 9:25 pm
Hi
I've decided I much prefer Audacity to Garage band. Audacity's more intuitive. So I want revert to Audacity with my new sound card. But has the mapping problem been solved?
Referring back to my OP.
'The stereo guitar sound from my Focusrite sound card is going via firewire then thunderbolt adapter into my Mac. It appears for some reason on inputs 5 & 6 of Audacity. However Audacity won't let me select 5 & 6 as inputs. When I select for example input 6 & record. I get 6 tracks appear (1 to 6) with my guitar sound on the bottom two (5&6).
I obviously only want two tracks for stereo guitar. So how can I achieve this without also getting tracks 1 to 4 on screen ?
Ideally if I could get the focusrite to send to tracks 1 & 2 of Audacity so I can then select that input as 1/2 stereo but how can I achieve this ?'
Post by Gale Andrews » Sun Nov 17, 2013 8:30 pm
Pobinr wrote:I've decided I much prefer Audacity to Garage band. Audacity's more intuitive. So I want revert to Audacity with my new sound card. But has the mapping problem been solved?
There has been no more work on this recently.
Of course if you compile Audacity you can try the patch yourself. If the patch no longer compiles then you can checkout Audacity from the time of the patch then it will compile. Here is some help with compiling: http://wiki.audacityteam.org/wiki/Building_On_Mac .
