I have Audacity v.2.0.3 using a PC 64-bit. I have an AIFF (.aifc) file of 96MB (2.5 hour interview) which I am trying to import for clean up of background noise. The file imports, but on playback it only plays the first few seconds in a loop.
What am I doing wrong?
AIFF File Import Problem
lightspout
- Quality Assurance
Re: AIFF File Import Problem
Have you installed FFmpeg http://manual.audacityteam.org/o/man/fa ... tml#ffdown ?
This may be necessary depending on what compressed format the AIFC actually contains.
Alternatively if you have iTunes you can drag the AIFC into iTunes and convert it to WAV (just choose WAV encoder instead of MP3 encoder in those steps).
lightspout
SOLVED!! Thanks very much.
- Quality Assurance
Did FFmpeg solve it or iTunes? It really helps us and others to know exactly what solved a problem.lightspout wrote:SOLVED!! Thanks very much.
