2.0.3 Click removal not working, sounds the same
checkin1
Post by checkin1 » Sat Jun 29, 2013 2:34 pm
I try Edit/Select All/Effect/Click removal,,,,,goes thru the removal graph, but none of the clicks & pops are removed.
I am useing Windows Media Player.
Re: 2.0.3 Click removal not working, sounds the same
Post by kozikowski » Sun Jun 30, 2013 5:49 am
I'm sure the instructions tell you to mess with the settings in the Click Removal tool control panel. The default sliders are only a guess and you have to tailor the tool to your recording. If you have a very noisy recording but the clicks are not prominent, the tool may not work right at all. Koz
waxcylinder
Post by waxcylinder » Sun Jun 30, 2013 1:06 pm
The best tool I've found (following a steer from Koz) is Brain Davies' excellent ClickRepair http://www.clickrepair.net/
and see this sticky thread: http://forum.audacityteam.org/viewtopic.php?f=28&t=1994
It costs a little - but you do get a 14-day free trial.
