want to increase volume of audio files in mkv videos
Feedback and Reviews for Audacity 2.x
This board is ONLY for general feedback and discussion about Audacity 2.X.
If you require help, or think you have found a "bug", please post on the forum board relevant to your operating system.
vivek.b
Post by vivek.b » Fri Jun 28, 2013 5:52 am
i m having bunch of movies in mkv files there are some movies having low audio sound. even though i keep my volume level at 100%. i m not satisfied with it. but at same level some movies audio sound are damn loud. how to level or adjust the volume of those audio files at desired level with no synchronization problem in audio.
thank you
Re: want to increase volume of audio files in mkv videos
Post by steve » Fri Jun 28, 2013 10:00 am
Audacity does not handle video, so if you want to process the sound in Audacity then you need to use a video application to put the processed sound back into the video.
Audacity can extract the audio content from many types of video file if you have ffmpeg installed: http://manual.audacityteam.org/o/man/fa ... tml#ffdown
To even out the volume level in a track you use "dynamic range compression" (often just called "compression").
Audacity includes a dynamic compression effect: http://manual.audacityteam.org/o/man/compressor.html
