envelope tool
Help for Audacity on macOS.
atomottokar
envelope tool
Post by atomottokar » Thu Jun 27, 2013 11:37 am
hello
how to use volume change on two track with enveloppe tool ?
bonjour
comment utiliser " volume change " sur deux pistes avec l'outil enveloppe
merci
Re: envelope tool
Post by steve » Thu Jun 27, 2013 12:27 pm
The envelope only acts on the track to which it is applied.
Envelopes cannot currently be copied separately from the audio.
So the only way to apply an envelope to two tracks is to draw two envelopes; one on each track.
atomottokar
Re: envelope tool
Post by atomottokar » Thu Jun 27, 2013 8:11 pm
hello
sorry did i understand correctly .
" So the only way to apply an envelope to two tracks is to draw two envelopes; one on each track "
so an envelope only apply for the track selected ! mono or stereo
thanks
Re: envelope tool
Post by steve » Fri Jun 28, 2013 12:45 am
Yes envelopes can be applied to mono or stereo tracks, but the envelope only applies to one track.
