Export to MP3 sounds like I'm in a pipe...
ixodid
Post by ixodid » Sun Jun 23, 2013 9:55 pm
I have .aup recording of voice that has fairly decent quality.
When I export to MP3, it sounds like I recorded it inside a pipe. Kind of a hollow or flute-like effect.
What settings should I use to minimize this effect when creating an MP3?
Trebor
Re: Export to MP3 sounds like I'm in a pipe...
Post by Trebor » Sun Jun 23, 2013 10:06 pm
IMO If the track is stereo then use an mp3 bit-rate ["quality"] of 256Kbps or the maximum which is 320kbps ...
http://manual.audacityteam.org/o/man/mp ... tions.html
If the track is mono , or the sample rate is below 44100Hz, then you can get away with less than 256kbps.
Reason: corrected link
