"Nyquist files missing" (SOLVED)
Help for Audacity on macOS.
KitL
Post by KitL » Thu May 30, 2013 6:12 am
Hello all, my first post here.
This is the error message that greets me each time I load Audacity:
Screen Shot 2013-05-30 at 4.01.29 PM.png (78.65 KiB) Viewed 2124 times
I am using A. on a MacBook Air, top specs, 10.8.3. My Audacity is 2.0.3. I recall I opened a zip file to load the software.
Any help appreciated, KL
Re: "Nyquist files missing"
Post by steve » Thu May 30, 2013 7:32 am
You have not installed Audacity correctly.
Probably the best way to fix it is to remove Audacity entirely, then reinstall it follow the instructions here: http://audacityteam.org/download/mac
KitL
Re: "Nyquist files missing" (SOLVED)
Post by KitL » Thu May 30, 2013 7:40 am
Thank you; this worked perfectly. Over and out from me.
