Missing Audio Data Block Files
This board is ONLY for general feedback and discussion about Audacity 2.X.
If you require help, or think you have found a "bug", please post on the forum board relevant to your operating system.
holycrosschurch
I recently had to get a new computer at work; therefore, I had to reinstall Audacity. We currently record our church service and I edit it to place on our website. Since reinstalling the software, I am receiving a warning box whenever I try to open files! The files are saved on a different computer. The warning says: Warning- Missing Audio Data Block File(s). Project check of "early-5-26-13_data" folder detected 3614 missing audio data (.au) blockfile(s), probably due to a bug, system crash, or accidental deletion. There is no way for Audacity to recover these missing files automatically." It then gives me options on opening the file by replacing the missing pieces with silence, closing the file, etc. I tried opening files that I know work (that I had used before switching computers) and I am getting the same message. Help!
Re: Missing Audio Data Block Files
To move an Audacity Project from one computer to another you need to move both the .AUP (project file) and the audio data.
This article explains how to manage Audacity Projects http://manual.audacityteam.org/o/man/au ... jects.html
It will probably be easier to export the old projects as WAV files and then copy the WAV files to the new computer rather than moving the entire project.
