I posted the following tale on Facebook earlier (http://www.facebook.com/FeRDNYC/posts/10201244930148639), but I thought I'd share it here.
Score one for transparent, open data structures and unobfuscated file formats.
I was able to recover (or, quickly reconstruct) hours' worth of work on an Audacity sound-editing project recently, after its audio data blocks were completely savaged by a hard drive crash. This wouldn't have been possible using any software that writes project data in a proprietary, binary format. Fortunately, Audacity's project files are standard XML, which ended up saving the day.
Because I still had the DVD with the original project input .WAVs, and the Audacity project file itself was still intact, I was able to open the original project (in replace-missing-blocks-with-silence mode) and use it as a guide for re-importing the source files onto the timeline. Then, I deleted the corrupted tracks and saved the re-"initialized" state in a new project file.
After closing Audacity, I reapplied all of my edit points, (complex) envelopes, and other parameterization to the re-imported tracks the "old-fashioned way": by opening the project files in my text editor, and cutting-and-pasting the relevant XML from the original .AUP into the new project file!
Audacity Success Story (Hooray for XML in .AUP files!)
This board is ONLY for general feedback and discussion about Audacity 2.X.
If you require help, or think you have found a "bug", please post on the forum board relevant to your operating system.
Re: Audacity Success Story (Hooray for XML in .AUP files!)
You must be logged in to see this Facebook page.
Meh. Well, that's Facebook for you, sorry! The post is Public, but I suppose there are varying degrees of "public". (Any logged-in Facebook user should be able to see it.)
...It was just me telling the same story I posted here (actually, a shorter & less detailed version), so you aren't missing anything.
