impossible to record
Help for Audacity on macOS.
maxitman
Post by maxitman » Sun May 19, 2013 6:48 pm
This is my final attempt. I have tried everything. What I want to do - is simply to record from my computer, whatever sound, music, whatever, but the only thing I can get to work is just the microphone, I have tried all sorts of combos, I have the linein, lames, everything, but it just won't record, no matter what. I have a macbook pro 10.6.8, audacity is 2.0.3, please help
Re: impossible to record
Post by kozikowski » Sun May 19, 2013 7:04 pm
The Mac version of "Stereo Mix" is Soundflower. Soundflower is a software package that sits between the computer playback and Audacity, effectively turning around the sound so you can record it. You didn't mention Soundflower anywhere in that message, so can I assume you didn't try that?
http://wiki.audacityteam.org/wiki/User: ... ming_audio
maxitman
Post by maxitman » Sun May 19, 2013 7:09 pm
sorry I forgot to mention that, but yes, I got soundflower, everything is there, but no recording, other than my microphone
Post by kozikowski » Sun May 19, 2013 7:18 pm
Audacity > Preferences > Devices > Recording. Koz
Screen shot 2013-05-19 at 12.10.14 PM.png (49.05 KiB) Viewed 1057 times
billw58
Post by billw58 » Sun May 19, 2013 7:19 pm
Did you follow the instructions in that link? The concept of "inputs" and "outputs" can be counter-intuitive when using Soundflower.
-- Bill
maxitman
Post by maxitman » Sun May 19, 2013 7:21 pm
well the strange thing is, when i push the recording button, it now moves forward, as in if recording, except it does not record...and I have everything set up just like your instructions...
maxitman
Post by maxitman » Sun May 19, 2013 7:22 pm
inputs.....outputs...... I am lost...
maxitman
Post by maxitman » Sun May 19, 2013 7:24 pm
and yes, I have this weird feeling that I am just completely out of synch, somehow I must be pushing the wrong buttons all the time, wrong combos, but as per that example you guys sent over, it should be correct
maxitman
Post by maxitman » Sun May 19, 2013 7:48 pm
WOW, and right Bill, I had it assbackwards,it works now.....although I now hear both the recording sound as well as the actual sound....but it records just fine. Thanks, I was so close, and yet, so far.....
