Recording Voice on Different Days, audio uneven
Damienb
Re: Recording Voice on Different Days, audio uneven
Post by Damienb » Sat May 18, 2013 12:18 pm
Should make it a default compressor in the next Audacity Release. Have it has "Podcast Compression"
Damien
Post by steve » Sat May 18, 2013 2:39 pm
Damienb wrote:Should make it a default compressor in the next Audacity Release. Have it has "Podcast Compression"
Damien
The 1.2.6 version cannot be included as it was released with a "non distributable" license. The author of theaudacitytopodcast has been given special dispensation to distribute the plug-in.
The 1.2.7 beta version was released under a MIT (open source) license, so that can be distributed, but there are some problems with that version that would need to be fixed.
