lost long session
Help for Audacity on macOS.
Re: lost long session
Post by kozikowski » Sun May 12, 2013 9:29 pm
Left out a step. You have to post some of the work. Since this is not Error Diagnostics any more, you can use mono, high quality MP3 (128 quality or better) and get quite a number of seconds posted on the forum. If you want to post a more serous, longer sample at even higher quality, I can host it on kozco.com. Let me know. Koz
