External decks, mixer, laptop & speakers with audacity?
MingWah
Re: External decks, mixer, laptop & speakers with audacity?
Post by MingWah » Sun May 12, 2013 10:02 pm
Thanks but that does the same as the one I already have, the DJ IO. I just need a way of gettin my output to my computer because atm my 2 decks use all the available outputs on the soundcard
Shaky
Post by Shaky » Mon May 13, 2013 7:43 am
MingWah wrote:Spending further money on another soundcard is frustrating considering I have only recently bought the DJ IO to use with traktor. All very pricey
Another option would be if you have a CD/DVD recorder etc, in the house, you can send the master output from the mixer straight into that, burn a CD with your mixes and then rip digitally via your laptop's CD drive.
Afterwards your can clean it up, do fades etc in Audacity.
It is not the most elegant solution but it will work.
Post by steve » Mon May 13, 2013 11:49 am
MingWah wrote:I just need a way of gettin my output to my computer because atm my 2 decks use all the available outputs on the soundcard
Could you clarify that.
What outputs are available on the 2 decks and where/what are they connected to?
Shaky
Post by Shaky » Tue May 14, 2013 7:14 am
If I am reading him correctly his decks are connected by usb to the computer where the functionality (jog wheels, pitch control, etc) act as a sort of midi controller for tracks otherwise played via Traktor.
Traktor then sends the virtual decks to the 2 outputs on his soundcard, that are then fed into separate channels on his analogue mixer.
There may be some confusion because his decks can also be used as CD players and have line outs for that purpose, but that is not the way he is going.
Post by steve » Tue May 14, 2013 1:15 pm
Shaky wrote:There may be some confusion because his decks can also be used as CD players and have line outs for that purpose
That is the issue that needs clarifying.
We've had several users with Traktor software and CD decks that have had trouble recording their mixes, but I don't think that question has ever been answered, so we are unable to help them.
MingWah
Post by MingWah » Fri May 17, 2013 11:53 am
This is the same as my current sound card. I just need and output from the card that goes to an input ony laptop. However my laptop has no input jacks at all! So im kinda stumped :(
