recording old audio cassettes (SOLVED)
Help for Audacity on macOS.
pdrose
Post by pdrose » Wed May 08, 2013 3:49 am
Newtime user. Don't know if question got posted. Trying to record old cassettes using headphone jack to line-in. Only hearing out of one speaker. Can it get it to play out of both?
Re: recording old audio cassettes
Post by kozikowski » Wed May 08, 2013 6:30 am
Audacity > Preferences > Devices > Recording > Channels > 2-Channel (Stereo).
Make sure your audio cable plug is all the way in.
Do you have two sockets like this?
http://www.kozco.com/tech/audacity/pix/MacLineIn.jpg
pdrose
Post by pdrose » Wed May 08, 2013 9:15 am
yes
pdrose
Post by pdrose » Wed May 08, 2013 12:55 pm
That didn't work. Still only hearing from one speaker.
billw58
Post by billw58 » Wed May 08, 2013 4:30 pm
Check your cable. Is it a 1/8" or 1/4" headphone jack? Do the plugs on both ends of the cable have three connections?
See: http://manual.audacityteam.org/man/How_ ... _equipment
Note the first picture.
-- Bill
pdrose
Post by pdrose » Wed May 08, 2013 8:52 pm
They are mini jacks with two ridges. I believe they're 1/8 (the same plug that goes into the "line-in" on the iMac.
pdrose
Post by pdrose » Wed May 08, 2013 9:35 pm
Got it! I pushed both jacks in hard and it must not have been making a good connection, because now it works. Thanks!
Re: recording old audio cassettes (SOLVED)
Post by steve » Thu May 09, 2013 5:20 pm
Marked as solved.
