Noise Removal duplicates whole track
DuncanL
Post by DuncanL » Sat Nov 15, 2008 12:57 pm
Hi,
Just installed the latest 1.3.6 (Program build date: Oct 24 2008) and the Noise Removal tool seems to have developed a problem. I get the noise profile from a section, select all and apply the filter. After much thinking, the entire track is duplicated at the end of the initial selection. Have I changed something somewhere or is this an issue?
Cheers.
Duncan
DuncanL
Re: Noise Removal duplicates whole track
Post by DuncanL » Sat Nov 15, 2008 6:55 pm
Very odd... been trying to pin it down, I initially assume it was due to the length of the audio tracks (90 minutes) but after trimming it down to just seconds it still went wrong. Saving and reloading the file made no difference, but staring from importing a wav or flac was fine.
Now I've finally worked out the problem -if you have a label track, the Noise Removal plugin creates a duplicate of the selected audio! No idea why that should be the case; but I'll just have to remember to do the noise removal before setting down the labels for exporting to individual files.
Post by kozikowski » Sun Nov 16, 2008 1:19 am
Sometimes you can get around wacky 1.3.6 problems by trashing your audacity configuration file. I'm not totally sure where it is on a Windows machine, but you can search for that. audacity.cfg is the usual suspect file name.
Post by steve » Tue Nov 18, 2008 9:22 pm
There is a new function in Audacity 1.3.6 called "Linking".
http://audacityteam.org/manual/index.ph ... dio_tracks
In certain situations this can cause peculiar bugs like this. The workaround is to switch off linking by clicking on the link button so that it is not depressed (near the zoom buttons).
