syncing two tracks?
kevin32
syncing two tracks?
Post by kevin32 » Sat May 04, 2013 3:14 am
This will be my first time syncing two tracks. The first track has a drum beat with a stable, consistent tempo. The second track is a piano-played piece with varying tempo. I want the piano-piece to match the tempo of the drum beat for the whole song. The only way I know to do this is using the tempo track and speeding up/slowing down parts of the piano track to match the drumbeat.
Is there an easier way to do this? Thanks.
Re: syncing two tracks?
Post by kozikowski » Sat May 04, 2013 4:45 am
You would have been good had the piano and drum played to a metronome. Having them wander during the song is going to be very interesting to fix.
