Mode d'emploi pour supprimer les clicks ?
chaber
Post by chaber » Mon Apr 29, 2013 3:29 pm
Bonjour,
Dans mon 1er post sur les ''craquements des vyniles'' j'ai bêtement fait état sur ce site d'une solution avec''clickrepair'' alors qu'un ami m'a fait remarquer qu'Audacity avait un fonction similaire....
j'ai donc essayé mais je ne sais pas quelles valeurs prendre comme limite de seuil par exemple;
Quelle est l'unité à prendre en compte (décibel ?...) et ou trouver l'échelle correspondante
Idem pour la largeur du pic
les essais que j'ai fait, un peu au hasard font disparaître des clicks et pas d'autres sans que je sache pourquoi
seule la fonction ''réparer'' est facile à utiliser
merci d'avance
chaber :?
Re: Mode d'emploi pour supprimer les clicks ?
Post by Gale Andrews » Tue Apr 30, 2013 6:50 am
The units are not exposed to the user - http://manual.audacityteam.org/man/Click_Removal/fr .
See also http://tinyurl.com/c73945n .
So due to the limited features of Click Removal, It is usually better to remove clicks using other Audacity methods, or use other software:
http://tinyurl.com/cfxvyco .
If you want, you can translate this answer for me ;)
chaber
Post by chaber » Tue Apr 30, 2013 5:57 pm
Hello,
thank you, do I have to use WAV type of files or is WMA also usable ?
about translation:
does your answer mean that these informations are not accessible by the ''usual'' users but only by the staff I would say ?
do you need only the 3 sentences of your answer to be translated?
chaber :?:
Post by Gale Andrews » Wed May 01, 2013 4:26 am
chaber wrote:do I have to use WAV type of files or is WMA also usable ?
The French FAQ is translated. Many of your questions are answered if you would look there:
http://manual.audacityteam.org/man/FAQ: ... /fr#ffdown .
chaber wrote:about translation:
It means that I am not a native French speaker and I do not always have time to use a translation machine to answer you in French.
No native French speakers on Audacity Team are now able to answer questions in French (see the pink message at the top of this page).
If you really want an answer and there is no answer here, you have to write in English:
http://forum.audacityteam.org/viewforum.php?f=45 .
