MAC OS 10.6.8 Won't Install
Help for Audacity on macOS.
smarout
Post by smarout » Mon Apr 29, 2013 7:13 am
I have The 10.6.8 OS and i can get audacity to work. Read through the forum and tried to do what was advised but no luck. Put the folder in apps and opened and still wont open. Got an error that said like error -1172. Can't figure out what the problem could be. Need any help please
Re: MAC OS 10.6.8 Won't Install
Post by kozikowski » Mon Apr 29, 2013 6:53 pm
Are you running Parallels and Windows on your Mac? Koz
smarout
Post by smarout » Mon Apr 29, 2013 7:06 pm
No, i had it partitioned at one point, but not anymore. I got rid of it. I cant open audacity at all. It crashes right away
Post by kozikowski » Mon Apr 29, 2013 7:10 pm
That's not the same thing. You get Audacity opening screens and then they crash, or you get an error message and Audacity never shows up at all?
smarout
Post by smarout » Mon Apr 29, 2013 7:26 pm
Oh im sorry. No it doesnt open at all. The icon bounces and bounces but never gets the dot next to it and never actually opens
Post by kozikowski » Mon Apr 29, 2013 8:33 pm
If you haven't done this yet, it's worth a shot.
Desktop > Go > Utilities > Disk Utilities > select your system drive > Verify Disk and Repair Permissions.
smarout
Post by smarout » Mon Apr 29, 2013 9:44 pm
still nothing. did both things and tried reinstalling, but still wont open
Post by Gale Andrews » Tue Apr 30, 2013 12:16 am
Please attach the Mac crash report and an image of Error 1172. Please see here for how to attach files http://forum.audacityteam.org/viewtopic ... 49&t=64936 .
Meantime have you tried setting audacity.cfg to prevent Audacity loading VST and Audio Unit plug-ins? Please see here http://wiki.audacityteam.org/wiki/User: ... ces_on_Mac .
Post by kozikowski » Tue Apr 30, 2013 12:29 am
I don't have an audacity.cfg and you may not either. There's instructions in that posting how to make one.
smarout
Post by smarout » Tue Apr 30, 2013 12:54 am
ill try getting rid of the vsts, but for now no 1172 error, but still these.
http://i.imgur.com/U4jw5yu.png
http://i.imgur.com/UrgnVaN.jpg
http://i.imgur.com/tSSLtmO.png
