Review Audacity 2.0.3
Feedback and Reviews for Audacity 2.x
This board is ONLY for general feedback and discussion about Audacity 2.X.
If you require help, or think you have found a "bug", please post on the forum board relevant to your operating system.
vpd
Operating System: Linux Debian
Post by vpd » Thu Apr 25, 2013 8:14 am
A little review (April 25th, 2013)
1) The things I really love:
- very handy to split/move/arrange elements from wav file (especially useful when mixing vocals/turntable cuts/effects);
- spectral view + sound repear = perfect & easy way to kick out clicks and pops in the sound;
- amazing option to record a new track with overdub (playing other tracks while recording);
- wide ranges of amazing effects/sound processes/plugins;
2) Thing that I don't like:
- When saving a project, Audacity copies the used elements (from the original wav files) in the project folder. Changing some of the original wav files doesn't effect the project after that;
- Saved project (in .aup format) remembers the folder path and when the entire project is zipped it won't work on a different machine/folder until the new path is set manually in the .aup file (open/edit as xml);
- In the edit menu there is no mix/crossfade/replace option;
- Silence in the beginning of tracks is ignored/skipped while exporting;
3) Things that make me mad:
- Mouse control (it's more than ridiculous and absolutely different than most of the WAV editors) - a configuration option is must.
Re: Review Audacity 2.0.3
Post by steve » Thu Apr 25, 2013 3:54 pm
Thanks for posting the review.
Picking up on a few points:
vpd wrote:Saved project (in .aup format) remembers the folder path and when the entire project is zipped it won't work on a different machine/folder until the new path is set manually in the .aup file (open/edit as xml);
Please see here (in the manual) for how to safely move projects: http://manual.audacityteam.org/o/man/au ... .html#move
The important step that you are missing is resolving "dependencies" to make the project self-contained.
vpd wrote:In the edit menu there is no mix/crossfade/replace option;
That is a long standing feature request. There has been quite a lot of experimental work in this area but not yet ready for release. This is an area that we can expect to find new features in the future. I've added your vote for this feature.
vpd wrote:Silence in the beginning of tracks is ignored/skipped while exporting;
Another long standing feature request that I hope will be resolved in future versions. I've added your vote.
vpd wrote:Mouse control (it's more than ridiculous and absolutely different than most of the WAV editors)
I quite understand. I've used quite a few other programs and every one of them seems to have its own way of mouse control. It used to make me mad each time I switched from Audition to Audacity - now it makes me mad each time I switch from, Audacity to Audition. It has also made me mad when switching between Audition and ProTools or SoundForge. It's just a question of familiarity and I don't see any way round it.
Post by Gale Andrews » Wed May 01, 2013 7:27 am
Picking up on the other points
vpd wrote: When saving a project, Audacity copies the used elements (from the original wav files) in the project folder. Changing some of the original wav files doesn't effect the project after that
See here for more discussion of why this is as it is:
http://forum.audacityteam.org/viewtopic ... 02#p195202
vpd wrote:Mouse control (it's more than ridiculous and absolutely different than most of the WAV editors) - a configuration option is must.
I added your vote for configurable mouse bindings.
