Projects and missing audio
This board is ONLY for general feedback and discussion about Audacity 2.X.
If you require help, or think you have found a "bug", please post on the forum board relevant to your operating system.
Lordchilde
One big problem with Audacity is that when you transfer a project to another machine (simply getting a new computer, for instance) Audacity ‘loses’ the original audio files... “Always copy all audio into project” is meaningless in this respect. “There is no way Audacity can recover these files automatically,” it states. Well, that’s fine. But other audio editorssequencers allow you to set a new path for the audio… but not Audacity. Bad omission.
Re: Projects and missing audio
How to safely move Audacity Projects is described in the manual: http://manual.audacityteam.org/o/man/au ... .html#move
Lordchilde
file > Check dependencies ... got it.
and keep the AUP file and _data folder together - they must both be in the same directory.Lordchilde wrote:file > Check dependencies ... got it.
