inserting marks in a file for ease of playback
jimr
Post by jimr » Fri Nov 14, 2008 2:23 pm
I can't seem to find a simple command for putting marks in a file to simplify cues for playback. Is there a quick way to do this?
jimr
waxcylinder
Re: inserting marks in a file for ease of playback
Post by waxcylinder » Fri Nov 14, 2008 2:43 pm
Placing a label at the current cursor position - use CTRL+B
Or to mark the current position while playing or recording use CTRL+M
This will create labels in a label track - afterwards you can jump from label to label with the tab key.
(Note that labels are also used to break recordings into tracks - the label mname is used as a filename/trackname.)
