Is it possible to save a file at its changed playback speed?
Feedback and Reviews for Audacity 2.x
This board is ONLY for general feedback and discussion about Audacity 2.X.
If you require help, or think you have found a "bug", please post on the forum board relevant to your operating system.
bronxsta
Post by bronxsta » Tue Apr 16, 2013 3:13 am
I'm an experimental psych student and need two music files as stimuli.
One slowed by 50%, one increased 150%.
I also only want to save a selection of the music.
Is it possible to save a selection that's had its speed altered?
I understand the playback speed dial on the toolbars. .50 slows music down 50%. But when I go to the effect menu and try to change speed by 50%, the music isn't as slowed as when I used the playback dial. Can someone explain?
Re: Is it possible to save a file at its changed playback sp
Post by Gale Andrews » Tue Apr 16, 2013 3:59 am
bronxsta wrote:I'm an experimental psych student and need two music files as stimuli.
Not with Play-at-Speed. Use Effect > Change Speed (which changes the project's audio data on disk).
If you don't want to change the pitch when changing the speed, use Change Tempo instead.
Or add a Time Track , set a range then click once to set a constant speed change. This does not change the project's audio data on disk unless you Tracks > Mix and Render. This is like Effect > Change Speed (the pitch changes with the speed change).
Then you can File > Export Selection assuming your selection is already dragged in the track.
bronxsta wrote:I understand the playback speed dial on the toolbars. .50 slows music down 50%. But when I go to the effect menu and try to change speed by 50%, the music isn't as slowed as when I used the playback dial. Can someone explain?
You want -50% in Effect > Change Speed or 50% in Time Track which is the same as 0.50x in Play-at-Speed. +50% in Change Speed or 150% in Time Track is the same as 1.50x in Play-at-Speed.
