HELP! Any beta ver crashes on launch but 1.25 works fine
xgman
Post by xgman » Wed Nov 12, 2008 10:38 pm
Ver 1.25 works perfectly. Every Beta since then gives me this on launch after asking me to choose the language, and then crashes and never starts: Any ideas? Intl MacPro osX.5
Process: Audacity [446]
Path: /Applications/MUTIMEDIA/Audacity Beta/Audacity.app/Contents/MacOS/Audacity
Identifier: net.sourceforge.audacity
Version: 1.3.6 (1.3.6)
Code Type: X86 (Native)
Parent Process: launchd [143]
Date/Time: 2008-11-12 17:36:29.044 -0500
OS Version: Mac OS X 10.5.5 (9F33)
Report Version: 6
Exception Type: EXC_BAD_ACCESS (SIGBUS)
Exception Codes: KERN_PROTECTION_FAILURE at 0x0000000000000000
Crashed Thread: 15
Re: HELP! Any beta ver crashes on launch but 1.25 works fine
Post by kozikowski » Thu Nov 13, 2008 12:08 am
So you're complaining that the unstable version of Audacity is unstable? Just wondering.
There are some very entertaining problems with 1.3.6, but I think I'm running 1.3.5 on my Intel machine (although under Tiger, not Leopard) and everything seems to be OK.
It tries to write to the kernel.........um.........
Nothing should ever try to do that except an official Patch from Apple...or a sound driver? What sound equipment do you have connected to your machine and can you try again with it all disconnected?
Do you have multiple users and/or classes of user on your machine? Do you have lots of room on your hard drive?
xgman
Post by xgman » Thu Nov 13, 2008 4:48 pm
Yes I have tons of room and only one login acct and again if I install 1.25, it works perfectly, but any of the 1.3x betas just crash as soon as I start the program after it initially asks for the language choice. I've tried deleting all traces of audacity and trying again and no go, yet as soon as I put the 1.25 version back, all works normally. I know it's beta, but there must be something causing this to not even load once. Does anyone have any idea why this may be happening and why this is so different than starting 1.25?
I have a mac pro with Komplett Live external sound. That shouldn't make any difference I would think. There must be something different in the way this 1.3x beta series is loading the program.
Post by kozikowski » Thu Nov 13, 2008 6:22 pm
<<<I have a mac pro with Komplett Live external sound.>>>
So you disconnected all that and uninstalled the drivers and what happened? 1.3 started running?
Audacity is a very simple sound program and it sometimes objects to running in a system it doesn't entirely understand.
xgman
Post by xgman » Fri Nov 14, 2008 8:16 pm
It's simple. 1.25 works perfectly and 1.3x versions crash as soon as you start them and the select language screen comes on. I would really like to be able to use the most recent version so I would like to figure this out. I don't get the conflict. I'm stumped.
Post by kozikowski » Sat Nov 15, 2008 4:48 am
So would I, but I'm out of ideas.
Did you find the Audacity Preference file? I think on most machines now it's audacity.cfg. People tend to leave that file alone when they "start over" and are stunned when the shiny new Audacity has exactly the same preferences and problems the old one did.
On my machine, it's...
HardDrive > Users > Koz > Library > audacity > audacity.cfg
Trashing that file will send Audacity back to First Birthday on the next launch.
xgman
Post by xgman » Sat Nov 15, 2008 8:59 pm
Sorry for this long post but, here is the beginning and end of my crash report. Maybe a Audacity tech could look at it??? This is driving me nuts!
Process: Audacity [1261]
Parent Process: launchd [97]
Date/Time: 2008-11-15 15:56:46.990 -0500
Report Version: 6
Crashed Thread: 15
Thread 0:
0 libSystem.B.dylib 0xffff06c1 __bzero + 193
1 com.joesoft.hal 0x15f64d05 initallcfg(liball_s*) + 37
2 com.joesoft.hal 0x15f75358 std::vector<std::basic_string<char, std::char_traits<char>, std::allocator<char> >, std::allocator<std::basic_string<char, std::char_traits<char>, std::allocator<char> > > >::erase(__gnu_cxx::__normal_iterator<std::basic_string<char, std::char_traits<char>, std::allocator<char> >*, std::vector<std::basic_string<char, std::char_traits<char>, std::allocator<char> >, std::allocator<std::basic_string<char, std::char_traits<char>, std::allocator<char> > > > >, __gnu_cxx::__normal_iterator<std::basic_string<char, std::char_traits<char>, std::allocator<char> >*, std::vector<std::basic_string<char, std::char_traits<char>, std::allocator<char> >, std::allocator<std::basic_string<char, std::char_traits<char>, std::allocator<char> > > > >) + 11112
3 com.joesoft.hal 0x15f76322 std::vector<std::basic_string<char, std::char_traits<char>, std::allocator<char> >, std::allocator<std::basic_string<char, std::char_traits<char>, std::allocator<char> > > >::erase(__gnu_cxx::__normal_iterator<std::basic_string<char, std::char_traits<char>, std::allocator<char> >*, std::vector<std::basic_string<char, std::char_traits<char>, std::allocator<char> >, std::allocator<std::basic_string<char, std::char_traits<char>, std::allocator<char> > > > >, __gnu_cxx::__normal_iterator<std::basic_string<char, std::char_traits<char>, std::allocator<char> >*, std::vector<std::basic_string<char, std::char_traits<char>, std::allocator<char> >, std::allocator<std::basic_string<char, std::char_traits<char>, std::allocator<char> > > > >) + 15154
4 com.joesoft.hal 0x15f79a13 AudioDeviceCreateIOProcIDOverride(unsigned long, long (*)(unsigned long, AudioTimeStamp const*, AudioBufferList const*, AudioTimeStamp const*, AudioBufferList*, AudioTimeStamp const*, void*), void*, long (**)(unsigned long, AudioTimeStamp const*, AudioBufferList const*, AudioTimeStamp const*, AudioBufferList*, AudioTimeStamp const*, void*)) + 163
5 ...pple.audio.units.Components 0x700133ce AUGenericOutputEntry + 16654
6 ...pple.audio.units.Components 0x7001421c AUGenericOutputEntry + 20316
7 ...pple.audio.units.Components 0x700143a8 AUHALEntry + 120
8 ...ple.CoreServices.CarbonCore 0x959e3ded CallComponentDispatch + 29
9 ...ple.CoreServices.CarbonCore 0x959e3dcd CallComponentOpen + 43
10 ...ple.CoreServices.CarbonCore 0x959e2469 OpenAComponent + 449
11 net.sourceforge.audacity 0x006bb6c5 soundtouch::TDStretchSSE::~TDStretchSSE() + 18261
12 net.sourceforge.audacity 0x006bcb3d soundtouch::TDStretchSSE::~TDStretchSSE() + 23501
13 net.sourceforge.audacity 0x006bd36a soundtouch::TDStretchSSE::~TDStretchSSE() + 25594
14 net.sourceforge.audacity 0x006ba665 soundtouch::TDStretchSSE::~TDStretchSSE() + 14069
15 net.sourceforge.audacity 0x0000c2b4 AudacityApp::~AudacityApp() + 10756
16 net.sourceforge.audacity 0x0000c6b0 AudacityApp::~AudacityApp() + 11776
17 net.sourceforge.audacity 0x0000c7ea AudacityApp::~AudacityApp() + 12090
18 net.sourceforge.audacity 0x001541ee wxPrintout::GetTitle() const + 67870
19 net.sourceforge.audacity 0x00155863 wxPrintout::GetTitle() const + 73619
20 net.sourceforge.audacity 0x00007fe0 0x1000 + 28640
21 net.sourceforge.audacity 0x000093a1 wxAppConsole::CallOnInit() + 17
22 net.sourceforge.audacity 0x0048f22b wxHashTable::~wxHashTable() + 2379
23 net.sourceforge.audacity 0x00002c58 0x1000 + 7256
24 net.sourceforge.audacity 0x000025a2 0x1000 + 5538
25 net.sourceforge.audacity 0x000024c9 0x1000 + 5321
end
Thread 15 crashed with X86 Thread State (32-bit):
eax: 0xb07a6ec0 ebx: 0x15f7772b ecx: 0x33470c90 edx: 0x00000102
edi: 0x2496fec0 esi: 0x24deb164 ebp: 0xb07a6b88 esp: 0xb07a690c
ss: 0x0000001f efl: 0x00010246 eip: 0x00000000 cs: 0x00000017
ds: 0x0000001f es: 0x0000001f fs: 0x0000001f gs: 0x00000037
cr2: 0x00000000
Binary Images:
0x1000 - 0x9b3fff +net.sourceforge.audacity 1.3.6 (1.3.6) <e55e4eb230cbb0cf971f2fc12bc0ef70> /Applications/MUTIMEDIA/Audacity Beta/Audacity.app/Contents/MacOS/Audacity
0xc7a000 - 0xc7bfe1 com.apple.textencoding.unicode 2.2 (2.2) <6566f38ef8ee61fab9aaecfb6a81f208> /System/Library/TextEncodings/Unicode Encodings.bundle/Contents/MacOS/Unicode Encodings
0xf95000 - 0xfa7fff +com.unsanity.ape 2.5 (2.5) <05296fb55e88a72c8528a373a17f4229> /Library/Frameworks/ApplicationEnhancer.framework/Versions/A/ApplicationEnhancer
0xfe8000 - 0xff0fff +com.marcmoini.smartscrollx_ape ??? (2.8.7) <37c271e384d02c3f48a66cf984f94737> /Users/ALAN/Library/Application Enhancers/Smart Scroll.ape/Contents/MacOS/Smart Scroll
0x14ca9000 - 0x14ccfffd +com.unsanity.windowshadex 4.2b3 (20080921) <d07f766b8173f8382150c0a79d23b9f6> /Library/Application Enhancers/WindowShade X.ape/Contents/MacOS/WindowShade X
0x14cf8000 - 0x14d13ffd +com.unsanity.windowshadex.cocoa 4.2b3 (???) <767f03e22839f8a4ef84ebeaaf79c849> /Library/Application Enhancers/WindowShade X.ape/Contents/PlugIns/WindowShade X Cocoa.ape/Contents/MacOS/WindowShade X Cocoa
0x14d35000 - 0x14d37fff +com.unsanity.menuextraenabler 1.0.3 (1.0.3) /Library/InputManagers/Menu Extra Enabler/Menu Extra Enabler.bundle/Contents/MacOS/Menu Extra Enabler
0x14e64000 - 0x14e69fe3 +com.squared5.SaveAsAVI 1.2 (1.2) /Library/QuickTime/Save as AVI.component/Contents/MacOS/Save as AVI
0x14e6d000 - 0x14e70fef com.apple.LiveType.component 2.1.3 (2.1.3) /Library/QuickTime/LiveType.component/Contents/MacOS/LiveType
0x14ebc000 - 0x14ebcfff +alias_1407.so ??? (???) /Library/Audio/Plug-Ins/LADSPA/alias_1407.so
0x15aa2000 - 0x15b07fde com.apple.LiveType.framework 2.1.3 (2.1.3) /System/Library/PrivateFrameworks/LiveType.framework/Versions/A/LiveType
0x15b27000 - 0x15b99fff +com.DivXInc.DivXDecoder 6.4.0 (6.4.0) /Library/QuickTime/DivX Decoder.component/Contents/MacOS/DivX Decoder
0x15f42000 - 0x15f45fff com.apple.audio.AudioIPCPlugIn 1.0.4 (1.0.4) <d3d0290949e9c6af9832c02fe3e855ee> /System/Library/Extensions/AudioIPCDriver.kext/Contents/Resources/AudioIPCPlugIn.bundle/Contents/MacOS/AudioIPCPlugIn
0x15f4b000 - 0x15f50fff com.apple.audio.AppleHDAHALPlugIn 1.5.7 (1.5.7a24) /System/Library/Extensions/AppleHDA.kext/Contents/PlugIns/AppleHDAHALPlugIn.bundle/Contents/MacOS/AppleHDAHALPlugIn
0x15f55000 - 0x15f7dff2 +com.joesoft.hal ??? (1.0.2.294) /Library/Audio/Plug-Ins/HAL/Hear.plugin/Contents/MacOS/Hear
0x15f8e000 - 0x15f92ffc +com.srslabs.iwow ??? (2.0) /Library/Audio/Plug-Ins/HAL/iWow.plugin/Contents/MacOS/iTea
0x16477000 - 0x16478fff +am_pitchshift_1433.so ??? (???) /Library/Audio/Plug-Ins/LADSPA/am_pitchshift_1433.so
0x16497000 - 0x16497fff +amp_1181.so ??? (???) /Library/Audio/Plug-Ins/LADSPA/amp_1181.so
0x164b0000 - 0x164b5feb +allpass_1895.so ??? (???) /Library/Audio/Plug-Ins/LADSPA/allpass_1895.so
0x164b9000 - 0x164bbfe7 +analogue_osc_1416.so ??? (???) /Library/Audio/Plug-Ins/LADSPA/analogue_osc_1416.so
0x164bf000 - 0x164c1fff +bandpass_a_iir_1893.so ??? (???) /Library/Audio/Plug-Ins/LADSPA/bandpass_a_iir_1893.so
0x164c5000 - 0x164c7fff +bandpass_iir_1892.so ??? (???) /Library/Audio/Plug-Ins/LADSPA/bandpass_iir_1892.so
0x164cb000 - 0x164ccff3 +bode_shifter_1431.so ??? (???) /Library/Audio/Plug-Ins/LADSPA/bode_shifter_1431.so
0x164d0000 - 0x164d1ff3 +bode_shifter_cv_1432.so ??? (???) /Library/Audio/Plug-Ins/LADSPA/bode_shifter_cv_1432.so
0x164d5000 - 0x164d8fff +butterworth_1902.so ??? (???) /Library/Audio/Plug-Ins/LADSPA/butterworth_1902.so
0x164dc000 - 0x164ddff7 +chebstortion_1430.so ??? (???) /Library/Audio/Plug-Ins/LADSPA/chebstortion_1430.so
0x164e1000 - 0x164e1ffb +comb_1190.so ??? (???) /Library/Audio/Plug-Ins/LADSPA/comb_1190.so
0x164e5000 - 0x164eaff3 +comb_1887.so ??? (???) /Library/Audio/Plug-Ins/LADSPA/comb_1887.so
0x164ee000 - 0x164eefeb +comb_splitter_1411.so ??? (???) /Library/Audio/Plug-Ins/LADSPA/comb_splitter_1411.so
0x16502000 - 0x16502fff +const_1909.so ??? (???) /Library/Audio/Plug-Ins/LADSPA/const_1909.so
0x16506000 - 0x16507fe7 +crossover_dist_1404.so ??? (???) /Library/Audio/Plug-Ins/LADSPA/crossover_dist_1404.so
0x1650b000 - 0x1650bfff +dc_remove_1207.so ??? (???) /Library/Audio/Plug-Ins/LADSPA/dc_remove_1207.so
0x1650f000 - 0x16510fff +decay_1886.so ??? (???) /Library/Audio/Plug-Ins/LADSPA/decay_1886.so
0x16514000 - 0x16515017 +decimator_1202.so ??? (???) /Library/Audio/Plug-Ins/LADSPA/decimator_1202.so
0x16519000 - 0x16519fff +declip_1195.so ??? (???) /Library/Audio/Plug-Ins/LADSPA/declip_1195.so
0x1651d000 - 0x1651efe7 +diode_1185.so ??? (???) /Library/Audio/Plug-Ins/LADSPA/diode_1185.so
0x16531000 - 0x16534fe7 +delay_1898.so ??? (???) /Library/Audio/Plug-Ins/LADSPA/delay_1898.so
0x1c630000 - 0x1c632feb +delayorama_1402.so ??? (???) /Library/Audio/Plug-Ins/LADSPA/delayorama_1402.so
0x1c636000 - 0x1c637fe7 +divider_1186.so ??? (???) /Library/Audio/Plug-Ins/LADSPA/divider_1186.so
0x1c63b000 - 0x1c63efe7 +dj_eq_1901.so ??? (???) /Library/Audio/Plug-Ins/LADSPA/dj_eq_1901.so
0x1c642000 - 0x1c643fff +dj_flanger_1438.so ??? (???) /Library/Audio/Plug-Ins/LADSPA/dj_flanger_1438.so
0x1c647000 - 0x1c649fff +dyson_compress_1403.so ??? (???) /Library/Audio/Plug-Ins/LADSPA/dyson_compress_1403.so
0x1c64d000 - 0x1c64e003 +fad_delay_1192.so ??? (???) /Library/Audio/Plug-Ins/LADSPA/fad_delay_1192.so
0x1c652000 - 0x1c653ffb +fast_lookahead_limiter_1913.so ??? (???) /Library/Audio/Plug-Ins/LADSPA/fast_lookahead_limiter_1913.so
0x1c657000 - 0x1c658ff7 +flanger_1191.so ??? (???) /Library/Audio/Plug-Ins/LADSPA/flanger_1191.so
0x1c65c000 - 0x1c65efef +fm_osc_1415.so ??? (???) /Library/Audio/Plug-Ins/LADSPA/fm_osc_1415.so
0x1c662000 - 0x1c662fff +foldover_1213.so ??? (???) /Library/Audio/Plug-Ins/LADSPA/foldover_1213.so
0x1c666000 - 0x1c666ffb +foverdrive_1196.so ??? (???) /Library/Audio/Plug-Ins/LADSPA/foverdrive_1196.so
0x1c66a000 - 0x1c66bfff +freq_tracker_1418.so ??? (???) /Library/Audio/Plug-Ins/LADSPA/freq_tracker_1418.so
0x1c68e000 - 0x1c68ffe7 +gate_1410.so ??? (???) /Library/Audio/Plug-Ins/LADSPA/gate_1410.so
0x1c693000 - 0x1c694fff +giant_flange_1437.so ??? (???) /Library/Audio/Plug-Ins/LADSPA/giant_flange_1437.so
0x1c698000 - 0x1c69cff3 +gong_1424.so ??? (???) /Library/Audio/Plug-Ins/LADSPA/gong_1424.so
0x1c6a0000 - 0x1c6a1fe7 +gong_beater_1439.so ??? (???) /Library/Audio/Plug-Ins/LADSPA/gong_beater_1439.so
0x1c6a5000 - 0x1c6bcfff +gsm_1215.so ??? (???) /Library/Audio/Plug-Ins/LADSPA/gsm_1215.so
0x1c6c0000 - 0x1c6c3fef +gverb_1216.so ??? (???) /Library/Audio/Plug-Ins/LADSPA/gverb_1216.so
0x1c6c7000 - 0x1c6c7fff +hard_limiter_1413.so ??? (???) /Library/Audio/Plug-Ins/LADSPA/hard_limiter_1413.so
0x1c6cb000 - 0x1c6cdfe3 +harmonic_gen_1220.so ??? (???) /Library/Audio/Plug-Ins/LADSPA/harmonic_gen_1220.so
0x1c6d1000 - 0x1c6d9ff7 +hermes_filter_1200.so ??? (???) /Library/Audio/Plug-Ins/LADSPA/hermes_filter_1200.so
0x1c6dd000 - 0x1c6dffff +highpass_iir_1890.so ??? (???) /Library/Audio/Plug-Ins/LADSPA/highpass_iir_1890.so
0x1c6e3000 - 0x1c6e3fff +hilbert_1440.so ??? (???) /Library/Audio/Plug-Ins/LADSPA/hilbert_1440.so
0x1c6e7000 - 0x1c6e7fff +impulse_1885.so ??? (???) /Library/Audio/Plug-Ins/LADSPA/impulse_1885.so
0x1c6eb000 - 0x1c6ebff3 +inv_1429.so ??? (???) /Library/Audio/Plug-Ins/LADSPA/inv_1429.so
0x1c6ef000 - 0x1c6effff +karaoke_1409.so ??? (???) /Library/Audio/Plug-Ins/LADSPA/karaoke_1409.so
0x1c6f3000 - 0x1c6f3fff +latency_1914.so ??? (???) /Library/Audio/Plug-Ins/LADSPA/latency_1914.so
0x1c6f7000 - 0x1c6f9fe7 +lcr_delay_1436.so ??? (???) /Library/Audio/Plug-Ins/LADSPA/lcr_delay_1436.so
0x1e3a8000 - 0x1e3aafff +lowpass_iir_1891.so ??? (???) /Library/Audio/Plug-Ins/LADSPA/lowpass_iir_1891.so
0x1e3ae000 - 0x1e3affe3 +ls_filter_1908.so ??? (???) /Library/Audio/Plug-Ins/LADSPA/ls_filter_1908.so
0x1e3b3000 - 0x1e3b3fff +matrix_ms_st_1421.so ??? (???) /Library/Audio/Plug-Ins/LADSPA/matrix_ms_st_1421.so
0x1e3b7000 - 0x1e3b8fff +matrix_spatialiser_1422.so ??? (???) /Library/Audio/Plug-Ins/LADSPA/matrix_spatialiser_1422.so
0x1e3bc000 - 0x1e3bcff7 +matrix_st_ms_1420.so ??? (???) /Library/Audio/Plug-Ins/LADSPA/matrix_st_ms_1420.so
0x1e3c0000 - 0x1e3c0fff +mod_delay_1419.so ??? (???) /Library/Audio/Plug-Ins/LADSPA/mod_delay_1419.so
0x1e3c4000 - 0x1e3c6fff +multivoice_chorus_1201.so ??? (???) /Library/Audio/Plug-Ins/LADSPA/multivoice_chorus_1201.so
0x1e3ca000 - 0x1e3ccfef +notch_iir_1894.so ??? (???) /Library/Audio/Plug-Ins/LADSPA/notch_iir_1894.so
0x1e3d0000 - 0x1e3d3017 +phasers_1217.so ??? (???) /Library/Audio/Plug-Ins/LADSPA/phasers_1217.so
0x1e3d7000 - 0x1e3daff7 +plate_1423.so ??? (???) /Library/Audio/Plug-Ins/LADSPA/plate_1423.so
0x1e3de000 - 0x1e3defe7 +pointer_cast_1910.so ??? (???) /Library/Audio/Plug-Ins/LADSPA/pointer_cast_1910.so
0x1e8bd000 - 0x1e96eff7 +imp_1199.so ??? (???) /Library/Audio/Plug-Ins/LADSPA/imp_1199.so
0x1e9c6000 - 0x1ea76fff +mbeq_1197.so ??? (???) /Library/Audio/Plug-Ins/LADSPA/mbeq_1197.so
0x1ea86000 - 0x1eb36fdf +pitch_scale_1193.so ??? (???) /Library/Audio/Plug-Ins/LADSPA/pitch_scale_1193.so
0x1eb56000 - 0x1ec06fff +pitch_scale_1194.so ??? (???) /Library/Audio/Plug-Ins/LADSPA/pitch_scale_1194.so
0x1ec26000 - 0x1ec26fff +rate_shifter_1417.so ??? (???) /Library/Audio/Plug-Ins/LADSPA/rate_shifter_1417.so
0x1ec2a000 - 0x1ec2bff7 +retro_flange_1208.so ??? (???) /Library/Audio/Plug-Ins/LADSPA/retro_flange_1208.so
0x1ec2f000 - 0x1ec31fff +revdelay_1605.so ??? (???) /Library/Audio/Plug-Ins/LADSPA/revdelay_1605.so
0x1ec35000 - 0x1ec36fef +ringmod_1188.so ??? (???) /Library/Audio/Plug-Ins/LADSPA/ringmod_1188.so
0x1ec3a000 - 0x1ec3b023 +satan_maximiser_1408.so ??? (???) /Library/Audio/Plug-Ins/LADSPA/satan_maximiser_1408.so
0x1ec3f000 - 0x1ec41fff +sc1_1425.so ??? (???) /Library/Audio/Plug-Ins/LADSPA/sc1_1425.so
0x1ec47000 - 0x1ec49fff +sc2_1426.so ??? (???) /Library/Audio/Plug-Ins/LADSPA/sc2_1426.so
0x1ec4f000 - 0x1ec51fff +sc3_1427.so ??? (???) /Library/Audio/Plug-Ins/LADSPA/sc3_1427.so
0x1ec57000 - 0x1ec59ff7 +sc4_1882.so ??? (???) /Library/Audio/Plug-Ins/LADSPA/sc4_1882.so
0x1ec5f000 - 0x1ec61ff7 +sc4m_1916.so ??? (???) /Library/Audio/Plug-Ins/LADSPA/sc4m_1916.so
0x1ec67000 - 0x1ec69fff +se4_1883.so ??? (???) /Library/Audio/Plug-Ins/LADSPA/se4_1883.so
0x1ec6f000 - 0x1ec70fe3 +shaper_1187.so ??? (???) /Library/Audio/Plug-Ins/LADSPA/shaper_1187.so
0x1ec74000 - 0x1ec78fff +sifter_1210.so ??? (???) /Library/Audio/Plug-Ins/LADSPA/sifter_1210.so
0x1ec7c000 - 0x1ec7dff7 +sin_cos_1881.so ??? (???) /Library/Audio/Plug-Ins/LADSPA/sin_cos_1881.so
0x1ec81000 - 0x1ec82ff7 +single_para_1203.so ??? (???) /Library/Audio/Plug-Ins/LADSPA/single_para_1203.so
0x1ec86000 - 0x1ec86ffb +sinus_wavewrapper_1198.so ??? (???) /Library/Audio/Plug-Ins/LADSPA/sinus_wavewrapper_1198.so
0x1ec8a000 - 0x1ec8afef +smooth_decimate_1414.so ??? (???) /Library/Audio/Plug-Ins/LADSPA/smooth_decimate_1414.so
0x1ec8e000 - 0x1ec8efff +split_1406.so ??? (???) /Library/Audio/Plug-Ins/LADSPA/split_1406.so
0x1ec92000 - 0x1ec93fff +step_muxer_1212.so ??? (???) /Library/Audio/Plug-Ins/LADSPA/step_muxer_1212.so
0x1ec97000 - 0x1ec97fff +surround_encoder_1401.so ??? (???) /Library/Audio/Plug-Ins/LADSPA/surround_encoder_1401.so
0x1ec9b000 - 0x1ec9cfff +svf_1214.so ??? (???) /Library/Audio/Plug-Ins/LADSPA/svf_1214.so
0x1eca0000 - 0x1eca1fe3 +tape_delay_1211.so ??? (???) /Library/Audio/Plug-Ins/LADSPA/tape_delay_1211.so
0x1eca5000 - 0x1eca6fef +transient_1206.so ??? (???) /Library/Audio/Plug-Ins/LADSPA/transient_1206.so
0x1ecaa000 - 0x1ecacff7 +triple_para_1204.so ??? (???) /Library/Audio/Plug-Ins/LADSPA/triple_para_1204.so
0x1ecb0000 - 0x1ecb103f +valve_1209.so ??? (???) /Library/Audio/Plug-Ins/LADSPA/valve_1209.so
0x1ecb5000 - 0x1ecb6057 +valve_rect_1405.so ??? (???) /Library/Audio/Plug-Ins/LADSPA/valve_rect_1405.so
0x1ecba000 - 0x1ecbdfeb +vynil_1905.so ??? (???) /Library/Audio/Plug-Ins/LADSPA/vynil_1905.so
0x1ecc1000 - 0x1ecc1fff +wave_terrain_1412.so ??? (???) /Library/Audio/Plug-Ins/LADSPA/wave_terrain_1412.so
0x1ecc5000 - 0x1ecc6fff +xfade_1915.so ??? (???) /Library/Audio/Plug-Ins/LADSPA/xfade_1915.so
0x1ecca000 - 0x1eccafff +zm1_1428.so ??? (???) /Library/Audio/Plug-Ins/LADSPA/zm1_1428.so
0x1ecce000 - 0x1ecd1ff7 +gverb_1216.so ??? (???) /Applications/MUTIMEDIA/Audacity Beta/plug-ins/gverb_1216.so
0x1ecd5000 - 0x1ecd5ffb +hard_limiter_1413.so ??? (???) /Applications/MUTIMEDIA/Audacity Beta/plug-ins/hard_limiter_1413.so
0x1ecd9000 - 0x1ecdbfff +sc4_1882.so ??? (???) /Applications/MUTIMEDIA/Audacity Beta/plug-ins/sc4_1882.so
0x1ece1000 - 0x1ecf9fcf +com.ikmultimedia.host.AmpliTubeJimiHendrix ??? (1.0) /Library/Audio/Plug-Ins/Components/AmpliTubeJimiHendrix.component/Contents/MacOS/AmpliTubeJimiHendrix
0x1ed0e000 - 0x1f2eafdf +com.ikmultimedia.vpa.AmpliTubeJimiHendrix 1.0 (1.0) /Library/Application Support/IK Multimedia/AmpliTube Jimi Hendrix/AmpliTubeJimiHendrix.vpa/Contents/MacOS/AmpliTubeJimiHendrix
0x1f41b000 - 0x1f439fe7 com.apple.OpenTransport 3.0 (3.0) /System/Library/PrivateFrameworks/OpenTransport.framework/OpenTransport
0x1f5fc000 - 0x1f5fcffd libmx.A.dylib ??? (???) /usr/lib/libmx.A.dylib
0x22d62000 - 0x22e3eff3 +com.tcelectronic.Assimilator Konnekt 1.2.5.2603 (Assimilator Konnekt 1.2.5.2603 Release) /Library/Audio/Plug-Ins/Components/Assimilator Konnekt.component/Contents/MacOS/Assimilator Konnekt
0x22f09000 - 0x22f41fdf +libEioPal.dylib ??? (???) /usr/local/lib/libEioPal.dylib
0x22f82000 - 0x22f9dffc com.apple.IOFireWireLib 3.4.4 (3.4.4) <479dd51d0b09f5b3aef30a67ef944d46> /System/Library/Extensions/IOFireWireFamily.kext/Contents/PlugIns/IOFireWireLib.plugin/Contents/MacOS/IOFireWireLib
0x23089000 - 0x2309bfd9 com.apple.FCP Uncompressed 422.component 1.5 (1.5) /Library/QuickTime/FCP Uncompressed 422.component/Contents/MacOS/FCP Uncompressed 422
0x230aa000 - 0x230c4fc3 com.apple.AppleIntermediateCodec 1.2 (145) /Library/QuickTime/AppleIntermediateCodec.component/Contents/MacOS/AppleIntermediateCodec
0x230cd000 - 0x230e1fdb +com.3ivx.videocodec 5.0.1 (5.0.1) /Library/QuickTime/3ivxVideoCodec.component/Contents/MacOS/3ivxVideoCodec
0x230ea000 - 0x2310dff7 com.apple.AppleProResDecoder 1.0 (50) /System/Library/QuickTime/AppleProResDecoder.component/Contents/MacOS/AppleProResDecoder
0x2313f000 - 0x23144ffb com.apple.AppleMPEG2Codec 1.0.1 (220) /Library/QuickTime/AppleMPEG2Codec.component/Contents/MacOS/AppleMPEG2Codec
0x2315e000 - 0x23383ffc +org.perian.Perian 1.1 (1.1) <1f0d751abac46ab4fe8b505bbdd89219> /Library/QuickTime/Perian.component/Contents/MacOS/Perian
0x23460000 - 0x236cdff7 +com.yourcompany.XviD_Codec ??? (1.0) /Library/QuickTime/XviD_Codec 1.0 alpha.component/Contents/MacOS/XviD_Codec
0x23bb0000 - 0x23df0fd2 +net.telestream.wmv.import 2.2.0.49 (2.2.0.49) /Library/QuickTime/Flip4Mac WMV Import.component/Contents/MacOS/Flip4Mac WMV Import
0x23e28000 - 0x23feafea +net.telestream.wmv.advanced 2.2.0.49 (2.2.0.49) /Library/QuickTime/Flip4Mac WMV Advanced.component/Contents/MacOS/Flip4Mac WMV Advanced
0x2402e000 - 0x24145ff8 +www.zygodigital.com ZyGoVideo version 4.0.4 (3.5.0.1) /Library/QuickTime/ZyGoVideo.component/Contents/MacOS/ZyGoVideo
0x2418f000 - 0x2435dfeb com.MyCometG3.avc1Decoder 0.7.7 (2008.06.01) /System/Library/QuickTime/avc1Decoder.component/Contents/MacOS/avc1Decoder
0x2442d000 - 0x24468fff com.apple.QuickTimeFireWireDV.component 7.5.5 (975) /System/Library/QuickTime/QuickTimeFireWireDV.component/Contents/MacOS/QuickTimeFireWireDV
0x24473000 - 0x244affe3 com.apple.AppleVAFramework 4.0.20 (4.0.20) /System/Library/PrivateFrameworks/AppleVA.framework/Versions/A/AppleVA
0x244b6000 - 0x244d5fe7 com.apple.IMXCodec 1.2 (140) /Library/QuickTime/IMXCodec.component/Contents/MacOS/IMXCodec
0x244ed000 - 0x24507fe3 com.apple.applepixletvideo 1.2.16 (1.2d16) <798930d46fb63202d054bbabf6e8c0e6> /System/Library/QuickTime/ApplePixletVideo.component/Contents/MacOS/ApplePixletVideo
0x24675000 - 0x24692fdc +com.mda-vst.AudioUnits 1.0.2 (1.0.2) /Library/Audio/Plug-Ins/Components/mda.component/Contents/MacOS/mda
0x2469d000 - 0x247c2fe7 +com.tcelectronic.Fabrik C Studio 1.2.7.3301 (Fabrik C Studio 1.2.7.3301 Release) <6c9db2f3b1cc27d2010337265dc2251b> /Library/Audio/Plug-Ins/Components/Fabrik C Studio.component/Contents/MacOS/Fabrik C Studio
0x247ff000 - 0x2481efed com.apple.audio.CoreAudioKit 1.5 (1.5) <795c36d256c2cead9607068b1f78e141> /System/Library/Frameworks/CoreAudioKit.framework/Versions/A/CoreAudioKit
0x24b32000 - 0x24c57fe7 +com.tcelectronic.Fabrik C Live 1.2.7.3301 (Fabrik C Live 1.2.7.3301 Release) <f00b9e06cdcd3118f5bf67efdb767ce2> /Library/Audio/Plug-Ins/Components/Fabrik C Live.component/Contents/MacOS/Fabrik C Live
0x24dc7000 - 0x24f43ffb +com.tcelectronic.Fabrik R Studio 1.2.7.3301 (Fabrik R Studio 1.2.7.3301 Release) <13b723cab8ab9d384dfffb8f00e352f2> /Library/Audio/Plug-Ins/Components/Fabrik R Studio.component/Contents/MacOS/Fabrik R Studio
0x255d6000 - 0x25752ffb +com.tcelectronic.Fabrik R Live 1.2.7.3301 (Fabrik R Live 1.2.7.3301 Release) <dff5b824403d0d05d6c03fbb851d38dd> /Library/Audio/Plug-Ins/Components/Fabrik R Live.component/Contents/MacOS/Fabrik R Live
0x25dfe000 - 0x25e1bfcf +com.ikmultimedia.audiounit.csrhall ??? (1.1) /Library/Audio/Plug-Ins/Components/CSR Hall.component/Contents/MacOS/CSR Hall
0x25e44000 - 0x25f39fcb +com.ikmultimedia.CSR VPA 1.x (???) <cd248200c37d4b1ab4d6e58a446a50b1> /Library/Application Support/IK Multimedia/CSR/CSR.vpa/Contents/MacOS/CSR
0x26002000 - 0x2601ffcf +com.ikmultimedia.audiounit.csrinverse ??? (1.1) /Library/Audio/Plug-Ins/Components/CSR Inverse.component/Contents/MacOS/CSR Inverse
0x26048000 - 0x26065fcf +com.ikmultimedia.audiounit.csrplate ??? (1.1) /Library/Audio/Plug-Ins/Components/CSR Plate.component/Contents/MacOS/CSR Plate
0x26095000 - 0x260b2fcf +com.ikmultimedia.audiounit.csrroom ??? (1.1) /Library/Audio/Plug-Ins/Components/CSR Room.component/Contents/MacOS/CSR Room
0x260e2000 - 0x261fbfff +com.tcelectronic.M40 Reverb 1.0.5.3143 (M40 Reverb 1.0.5.3143 Release) <273506486fb3a886d2b60c21183807c8> /Library/Audio/Plug-Ins/Components/M40 Reverb.component/Contents/MacOS/M40 Reverb
0x26640000 - 0x26dedfcf +Guitar Rig 2.MusicDevice.component 2.2.1.006 (2.2.1) /Library/Audio/Plug-Ins/Components/GuitarRig 2.component/Contents/MacOS/GuitarRig 2
0x2752d000 - 0x2754aff3 com.apple.audio.midi.CoreMIDI 1.6 (42) /System/Library/Frameworks/CoreMIDI.framework/Versions/A/CoreMIDI
0x27562000 - 0x27580fe3 libexpat.1.dylib ??? (???) <4b0320ecb5a2954cb3ad877a9aaf6ad2> /usr/lib/libexpat.1.dylib
0x28822000 - 0x28852fd6 +com.pspaudioware.effects.mixbass2 ??? (2.0.0) /Library/Audio/Plug-Ins/Components/PSP MixBass2.component/Contents/MacOS/PSP MixBass2
0x2889b000 - 0x288e30ae +com.pspaudioware.plugins.pspmb20 2.0.0 (2.0.0) /Library/Audio/Plug-Ins/Components/PSP MixBass2.component/Contents/Resources/PSP MixBass2.vst/Contents/MacOS/PSP MixBass2
0x28a29000 - 0x28a59fd6 +com.pspaudioware.effects.mixgate2 ??? (2.0.0) /Library/Audio/Plug-Ins/Components/PSP MixGate2.component/Contents/MacOS/PSP MixGate2
0x28aa2000 - 0x28ae5fd6 +com.pspaudioware.plugins.pspev 2.0.0 (2.0.0) /Library/Audio/Plug-Ins/Components/PSP MixGate2.component/Contents/Resources/PSP MixGate2.vst/Contents/MacOS/PSP MixGate2
0x28bf5000 - 0x28c25fd6 +com.pspaudioware.effects.mixpressor2 ??? (2.0.0) /Library/Audio/Plug-Ins/Components/PSP MixPressor2.component/Contents/MacOS/PSP MixPressor2
0x28c6e000 - 0x28cbf2f6 +com.pspaudioware.plugins.pspmp20 1.5.2 (2.0.0) /Library/Audio/Plug-Ins/Components/PSP MixPressor2.component/Contents/Resources/PSP MixPressor2.vst/Contents/MacOS/PSP MixPressor2
0x28f00000 - 0x28f2ffd6 +com.pspaudioware.effects.masterq ??? (1.5.2) /Library/Audio/Plug-Ins/Components/PSP MasterQ.component/Contents/MacOS/PSP MasterQ
0x28f70000 - 0x28fd3442 +com.pspaudioware.plugins.pspmq 1.5.2 (1.5.2) /Library/Audio/Plug-Ins/Components/PSP MasterQ.component/Contents/Resources/PSP MasterQ.vst/Contents/MacOS/PSPMasterQ
0x2915f000 - 0x2918ffd6 +com.pspaudioware.effects.mixsaturator2 ??? (2.0.0) /Library/Audio/Plug-Ins/Components/PSP MixSaturator2.component/Contents/MacOS/PSP MixSaturator2
0x291d8000 - 0x29223fee +com.pspaudioware.plugins.pspms20 2.0.0 (2.0.0) /Library/Audio/Plug-Ins/Components/PSP MixSaturator2.component/Contents/Resources/PSP MixSaturator2.vst/Contents/MacOS/PSP MixSaturator2
0x2933f000 - 0x2936ffd6 +com.pspaudioware.effects.mixtreble2 ??? (2.0.0) /Library/Audio/Plug-Ins/Components/PSP MixTreble2.component/Contents/MacOS/PSP MixTreble2
0x293b8000 - 0x2940bfe6 +com.pspaudioware.plugins.pspmp20 2.0.0 (2.0.0) /Library/Audio/Plug-Ins/Components/PSP MixTreble2.component/Contents/Resources/PSP MixTreble2.vst/Contents/MacOS/PSP MixTreble2
0x2956d000 - 0x295a7fe6 +com.pspaudioware.effects.pspev ??? (1.5.4) /Library/Audio/Plug-Ins/Components/PSP EasyVerb.component/Contents/MacOS/PSP EasyVerb
0x295f0000 - 0x2965cfd6 +com.pspaudioware.plugins.pspev 1.5.2 (1.5.2) /Library/Audio/Plug-Ins/Components/PSP EasyVerb.component/Contents/Resources/PSP EasyVerb.vst/Contents/MacOS/PSP EasyVerb
0x29e8d000 - 0x29ebcfc6 +com.pspaudioware.effects.pspneon ??? (1.5.0) /Library/Audio/Plug-Ins/Components/PSP Neon.component/Contents/MacOS/PSP Neon
0x29f05000 - 0x2a02afe2 +com.pspaudioware.plugins.pspneon ??? (1.5.0) /Library/Audio/Plug-Ins/Components/PSP Neon.component/Contents/Resources/PSP Neon.vst/Contents/MacOS/PSPNeon
0x2a22d000 - 0x2a25cfd6 +com.pspaudioware.effects.vw2 ??? (2.1.4) /Library/Audio/Plug-Ins/Components/PSP VintageWarmer2.component/Contents/MacOS/PSP VintageWarmer2
0x2a2a5000 - 0x2a303002 +com.pspaudioware.plugins.pspvw2 2.1.4 (2.1.4) /Library/Audio/Plug-Ins/Components/PSP VintageWarmer2.component/Contents/Resources/PSP VintageWarmer2.vst/Contents/MacOS/PSP VintageWarmer2
0x2a39c000 - 0x2a3cbff6 +com.pspaudioware.effects.vintagewarmer ??? (2.1.4) /Library/Audio/Plug-Ins/Components/PSP VintageWarmer.component/Contents/MacOS/PSP VintageWarmer
0x2a414000 - 0x2a471ff2 +com.pspaudioware.plugins.pspvw 2.1.4 (2.1.4) /Library/Audio/Plug-Ins/Components/PSP VintageWarmer.component/Contents/Resources/PSP VintageWarmer.vst/Contents/MacOS/PSP VintageWarmer
0x2a4dd000 - 0x2a573ff7 +com.tcelectronic.Integrator 1.2.7.3301 (Integrator 1.2.7.3301 Release) <125f3824f9866737b81d7e9583749d62> /Library/Audio/Plug-Ins/Components/Integrator.component/Contents/MacOS/Integrator
0x2a65e000 - 0x2a783feb +com.tcelectronic.Fabrik C 1.2.7.3302 (Fabrik C 1.2.7.3302 Release) <b3726dce0d4206b220827b8a14a2e41e> /Library/Audio/Plug-Ins/Components/Fabrik C Konnekt.component/Contents/MacOS/Fabrik C
0x2a92a000 - 0x2a9c7feb +com.tcelectronic.ResFilter Konnekt 1.2.5.1965 (ResFilter Konnekt 1.2.5.1965 Release) <4bf22e6620d641e3978591797e424f11> /Library/Audio/Plug-Ins/Components/ResFilter Konnekt.component/Contents/MacOS/ResFilter Konnekt
0x2aa73000 - 0x2aa75fff +libTCMsgSrv2.dylib ??? (???) <927d25dea2f646868864145a16d37181> /usr/local/lib/libTCMsgSrv2.dylib
0x2ab8b000 - 0x2ad08fe7 +com.tcelectronic.Fabrik R 1.2.7.3302 (Fabrik R 1.2.7.3302 Release) <4c7098e8cbf7bc6f6599820d1f67a10f> /Library/Audio/Plug-Ins/Components/Fabrik R Konnekt.component/Contents/MacOS/Fabrik R
0x2aeff000 - 0x2b27aff7 +com.wavearts.plugin.MRClick ??? (5.45) <63dda68353d2d7bd175a2531babf1400> /Library/Audio/Plug-Ins/Components/MR Click.component/Contents/MacOS/MR Click
0x2b579000 - 0x2b8f7ff7 +com.wavearts.plugin.MRGate ??? (5.45) <b93042bb6c2ca9ab85f5b14637c9cafc> /Library/Audio/Plug-Ins/Components/MR Gate.component/Contents/MacOS/MR Gate
0x2bc03000 - 0x2bf81fff +com.wavearts.plugin.MRHum ??? (5.45) <5b89b361997c1095a5cae62f711b8722> /Library/Audio/Plug-Ins/Components/MR Hum.component/Contents/MacOS/MR Hum
0x2c28c000 - 0x2c60bffb +com.wavearts.plugin.MRNoise ??? (5.45) <35ce916790f6082f35a8c340477e159b> /Library/Audio/Plug-Ins/Components/MR Noise.component/Contents/MacOS/MR Noise
0x2d118000 - 0x2d4a2ff4 +com.wavearts.plugin.Restore ??? (5.45) <6218aeafedfc5e4d0b98f086305d613f> /Library/Audio/Plug-Ins/Components/Master Restoration.component/Contents/MacOS/Master Restoration
0x2d7b4000 - 0x2d7ccfc7 +com.ikmultimedia.effects.amplitube2 ??? (2.1.0) /Library/Audio/Plug-Ins/Components/AmpliTube2.component/Contents/MacOS/AmpliTube2
0x2d7e1000 - 0x2e02efcf +com.ikmultimedia.amplitube2 2.1.0 (2.1.0) /Library/Application Support/IK Multimedia/AmpliTube2/AmpliTube2.vpa/Contents/MacOS/Amplitube2
0x3214b000 - 0x32163fe7 +com.ikmultimedia.effects.ampegsvx ??? (1.1.1) /Library/Audio/Plug-Ins/Components/AmpegSVX.component/Contents/MacOS/AmpegSVX
0x32809000 - 0x32d62fe7 +com.ikmultimedia.ampegsvx 1.1.1 (1.1.1) /Library/Application Support/IK Multimedia/AmpegSVX/AmpegSVX.vpa/Contents/MacOS/AmpegSVX
0x70000000 - 0x700e3ff2 com.apple.audio.units.Components 1.5.1 (1.5.1) /System/Library/Components/CoreAudio.component/Contents/MacOS/CoreAudio
0x8fe00000 - 0x8fe2da53 dyld 96.2 (???) <5013f43c4d2c33c9619011f103ec3238> /usr/lib/dyld
0x90116000 - 0x90123fe7 com.apple.opengl 1.5.7 (1.5.7) <db835aeb1ffca9f5b5647dd0829a5b2c> /System/Library/Frameworks/OpenGL.framework/Versions/A/OpenGL
0x90124000 - 0x9012efeb com.apple.audio.SoundManager 3.9.2 (3.9.2) <caa41909dcb5a18a94bc68cd13999bd5> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/CarbonSound.framework/Versions/A/CarbonSound
0x9012f000 - 0x9013bffe libGL.dylib ??? (???) /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGL.dylib
0x9013c000 - 0x90203ff2 com.apple.vImage 3.0 (3.0) /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vImage.framework/Versions/A/vImage
0x90204000 - 0x90204ffa com.apple.CoreServices 32 (32) <2760719f7a81e8c2bdfd15b0939abc29> /System/Library/Frameworks/CoreServices.framework/Versions/A/CoreServices
0x90205000 - 0x9021bfe7 com.apple.CoreVideo 1.5.1 (1.5.1) <001910004257f1386724398f584b30b5> /System/Library/Frameworks/CoreVideo.framework/Versions/A/CoreVideo
0x9021c000 - 0x90497fe7 com.apple.Foundation 6.5.6 (677.21) <5cfa0aa8b9b43193955d601ba6c2591a> /System/Library/Frameworks/Foundation.framework/Versions/C/Foundation
0x90498000 - 0x9052bff3 com.apple.ApplicationServices.ATS 3.4 (???) <a96cd91dabc68545183c11de8f92c7e4> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ATS.framework/Versions/A/ATS
0x90641000 - 0x90651fff com.apple.speech.synthesis.framework 3.7.1 (3.7.1) <06d8fc0307314f8ffc16f206ad3dbf44> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/SpeechSynthesis.framework/Versions/A/SpeechSynthesis
0x9080e000 - 0x908f3ff3 com.apple.CoreData 100.1 (186) <9187380c86061cb4c37b6bec8abeae75> /System/Library/Frameworks/CoreData.framework/Versions/A/CoreData
0x908f4000 - 0x909d8fef com.apple.JavaScriptCore 5528 (5528.1) <a634d0260034c1c00a8859e29815e86c> /System/Library/Frameworks/JavaScriptCore.framework/Versions/A/JavaScriptCore
0x909d9000 - 0x909effff com.apple.DictionaryServices 1.0.0 (1.0.0) <7e9ff586b5c9d02b09e2a5527d98524f> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/DictionaryServices.framework/Versions/A/DictionaryServices
0x909f0000 - 0x90a32fef com.apple.NavigationServices 3.5.2 (163) <91844980804067b07a0b6124310d3f31> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/NavigationServices.framework/Versions/A/NavigationServices
0x90a33000 - 0x90a51fff libresolv.9.dylib ??? (???) <a8018c42930596593ddf27f7c20fe7af> /usr/lib/libresolv.9.dylib
0x90a52000 - 0x90a91fef libTIFF.dylib ??? (???) <3589442575ac77746ae99ecf724f5f87> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ImageIO.framework/Versions/A/Resources/libTIFF.dylib
0x90a92000 - 0x90aa0ffd libz.1.dylib ??? (???) <545ca09467025f77131cfac09d8b9375> /usr/lib/libz.1.dylib
0x90d10000 - 0x90d59fef com.apple.Metadata 10.5.2 (398.22) <a6b676925dd832780daf991e79adfebd> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/Metadata.framework/Versions/A/Metadata
0x90f08000 - 0x90f62ff7 com.apple.CoreText 2.0.3 (???) <1f1a97273753e6cfea86c810d6277680> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/CoreText.framework/Versions/A/CoreText
0x90f63000 - 0x90fefff7 com.apple.LaunchServices 290 (290) <61af37aac50984d220dd176f777e3b72> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/LaunchServices.framework/Versions/A/LaunchServices
0x90ff0000 - 0x91077ff7 libsqlite3.0.dylib ??? (???) <11311084bc4be9d4555dfac74fe7218a> /usr/lib/libsqlite3.0.dylib
0x91078000 - 0x91714fff com.apple.CoreGraphics 1.351.33 (???) <481a77e81d9e53589a05e80cfa90bbb5> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/CoreGraphics.framework/Versions/A/CoreGraphics
0x91715000 - 0x917b7ff3 com.apple.QuickTimeImporters.component 7.5.5 (975) /System/Library/QuickTime/QuickTimeImporters.component/Contents/MacOS/QuickTimeImporters
0x917b8000 - 0x91842fe3 com.apple.DesktopServices 1.4.7 (1.4.7) <d16642ba22c32f67be793ebfbe67ca3a> /System/Library/PrivateFrameworks/DesktopServicesPriv.framework/Versions/A/DesktopServicesPriv
0x91843000 - 0x91be0fe7 com.apple.QuartzCore 1.5.5 (1.5.5) <82435993614a3fff1236be18f82188bf> /System/Library/Frameworks/QuartzCore.framework/Versions/A/QuartzCore
0x91be6000 - 0x91beefff com.apple.DiskArbitration 2.2.1 (2.2.1) <42908e7ecc17a83cec4afef2850ec79e> /System/Library/Frameworks/DiskArbitration.framework/Versions/A/DiskArbitration
0x91bef000 - 0x91f11fe2 com.apple.QuickTime 7.5.5 (975) <429f2e4563cb3e7878a1d9583a83ebeb> /System/Library/Frameworks/QuickTime.framework/Versions/A/QuickTime
0x91f57000 - 0x92038ff7 libxml2.2.dylib ??? (???) <de34eb9b43eb7d4a4e0b7f25529efa12> /usr/lib/libxml2.2.dylib
0x92039000 - 0x920ccfff com.apple.ink.framework 101.3 (86) <dfa9debcd7537849d228021d1d9c0f63> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/Ink.framework/Versions/A/Ink
0x920cd000 - 0x920d8fe7 libCSync.A.dylib ??? (???) <86d2f2e167ba6f74f45a186f5c7f8980> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/CoreGraphics.framework/Versions/A/Resources/libCSync.A.dylib
0x920de000 - 0x920e0fff com.apple.securityhi 3.0 (30817) <020419ad33b8638b174e1a472728a894> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/SecurityHI.framework/Versions/A/SecurityHI
0x920e1000 - 0x9211ffff libGLImage.dylib ??? (???) <f0fe2252f6b1ca341bc7837fe2dcf11a> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGLImage.dylib
0x92120000 - 0x92120ff8 com.apple.ApplicationServices 34 (34) <e9cd7c823062c4382d89e3c9997f4739> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/ApplicationServices
0x922b2000 - 0x923a6ff4 libiconv.2.dylib ??? (???) <3f183527811098bb7332f67a1f902bfd> /usr/lib/libiconv.2.dylib
0x923b4000 - 0x92494fff libobjc.A.dylib ??? (???) <7b92613fdf804fd9a0a3733a0674c30b> /usr/lib/libobjc.A.dylib
0x92495000 - 0x924ccfff com.apple.SystemConfiguration 1.9.2 (1.9.2) <8b26ebf26a009a098484f1ed01ec499c> /System/Library/Frameworks/SystemConfiguration.framework/Versions/A/SystemConfiguration
0x924cd000 - 0x92605ff7 libicucore.A.dylib ??? (???) <3d8fdaf51c2664ab620f1688203caf26> /usr/lib/libicucore.A.dylib
0x92606000 - 0x92606ffc com.apple.audio.units.AudioUnit 1.5 (1.5) /System/Library/Frameworks/AudioUnit.framework/Versions/A/AudioUnit
0x92641000 - 0x92648ffe libbsm.dylib ??? (???) <5582985a86ea36504cca31788bccf963> /usr/lib/libbsm.dylib
0x92649000 - 0x9277bfff com.apple.CoreFoundation 6.5.4 (476.15) <e2869ad6dc1dd289f21b305b0bea9158> /System/Library/Frameworks/CoreFoundation.framework/Versions/A/CoreFoundation
0x9277c000 - 0x92800fe3 com.apple.CFNetwork 339.5 (339.5) <c6565c13b0356e1d4bb99a68398d558b> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/CFNetwork.framework/Versions/A/CFNetwork
0x92801000 - 0x92801fff com.apple.Carbon 136 (136) <ec1d4184925e652dbe1b9200a5a552ec> /System/Library/Frameworks/Carbon.framework/Versions/A/Carbon
0x92820000 - 0x92827fff com.apple.agl 3.0.9 (AGL-3.0.9) <aeab67ef267f8295ae80fddc197b52a5> /System/Library/Frameworks/AGL.framework/Versions/A/AGL
0x9284b000 - 0x9284bffd com.apple.Accelerate.vecLib 3.4.2 (vecLib 3.4.2) /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/vecLib
0x9284f000 - 0x92877fff libcups.2.dylib ??? (???) <1031ca5b692b80a9568e57a342b60157> /usr/lib/libcups.2.dylib
0x92878000 - 0x9287efff com.apple.print.framework.Print 218.0.2 (220.1) <2979f3be4e7e8adc875bf21658e9be94> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/Print.framework/Versions/A/Print
0x9292e000 - 0x9292fffc libffi.dylib ??? (???) <596e0dbf626b211741cecaa9698f271b> /usr/lib/libffi.dylib
0x92930000 - 0x92980ff7 com.apple.HIServices 1.7.0 (???) <f83f0cb838a646c69f08fd38a31265f3> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/HIServices.framework/Versions/A/HIServices
0x92981000 - 0x92986fff com.apple.CommonPanels 1.2.4 (85) <3b64ef0de184d09c6f99a1a7e77e42be> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/CommonPanels.framework/Versions/A/CommonPanels
0x92a99000 - 0x92a9bff1 com.apple.QuickTimeH264.component 7.5.5 (975) /System/Library/QuickTime/QuickTimeH264.component/Contents/MacOS/QuickTimeH264
0x92a9c000 - 0x92b16ff8 com.apple.print.framework.PrintCore 5.5.3 (245.3) <222dade7b33b99708b8c09d1303f93fc> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/PrintCore.framework/Versions/A/PrintCore
0x92b66000 - 0x92bc2ff7 com.apple.htmlrendering 68 (1.1.3) <a9f65fa1c4668dc7c49af5bf7d5287ad> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/HTMLRendering.framework/Versions/A/HTMLRendering
0x92bc3000 - 0x92bf0feb libvDSP.dylib ??? (???) <2ee4eb005babc90eaa352b33eb09226e> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libvDSP.dylib
0x92bf1000 - 0x92bf3ff5 libRadiance.dylib ??? (???) <8a844202fcd65662bb9ab25f08c45a62> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ImageIO.framework/Versions/A/Resources/libRadiance.dylib
0x92bf4000 - 0x92bf4ffd com.apple.Accelerate 1.4.2 (Accelerate 1.4.2) /System/Library/Frameworks/Accelerate.framework/Versions/A/Accelerate
0x92bf5000 - 0x93e6fffe com.apple.QuickTimeComponents.component 7.5.5 (975) /System/Library/QuickTime/QuickTimeComponents.component/Contents/MacOS/QuickTimeComponents
0x93e70000 - 0x93eaafe7 com.apple.coreui 1.2 (62) /System/Library/PrivateFrameworks/CoreUI.framework/Versions/A/CoreUI
0x93eab000 - 0x93f5bfff edu.mit.Kerberos 6.0.12 (6.0.12) <da7253e3fb7e47e46cb46d47ed320ffc> /System/Library/Frameworks/Kerberos.framework/Versions/A/Kerberos
0x93f5c000 - 0x9442df3e libGLProgrammability.dylib ??? (???) <fe1a33d4919c121aab831ad516da6a89> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGLProgrammability.dylib
0x9442e000 - 0x9442effb com.apple.installserver.framework 1.0 (8) /System/Library/PrivateFrameworks/InstallServer.framework/Versions/A/InstallServer
0x9442f000 - 0x94bf7fff com.apple.WebCore 5528 (5528.1) <bb24a083efdb00e9045ce73c5c97959c> /System/Library/Frameworks/WebKit.framework/Versions/A/Frameworks/WebCore.framework/Versions/A/WebCore
0x94bf8000 - 0x94bfcfff libGIF.dylib ??? (???) <572a32e46e33be1ec041c5ef5b0341ae> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ImageIO.framework/Versions/A/Resources/libGIF.dylib
0x94c17000 - 0x94cd1fe3 com.apple.CoreServices.OSServices 226.5 (226.5) <2a135d4fb16f4954290f7b72b4111aa3> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/OSServices.framework/Versions/A/OSServices
0x94cd2000 - 0x94d4ffef libvMisc.dylib ??? (???) /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libvMisc.dylib
0x94d50000 - 0x94d57fe9 libgcc_s.1.dylib ??? (???) <28a7cbc3a5ca2982d124668306f422d9> /usr/lib/libgcc_s.1.dylib
0x94d58000 - 0x94de3fff com.apple.framework.IOKit 1.5.1 (???) <324526f69e1443f2f9fb722cc88a23ec> /System/Library/Frameworks/IOKit.framework/Versions/A/IOKit
0x94de4000 - 0x94dfcfff com.apple.openscripting 1.2.8 (???) <572c7452d7e740e8948a5ad07a99602b> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/OpenScripting.framework/Versions/A/OpenScripting
0x94dfd000 - 0x94e5affb libstdc++.6.dylib ??? (???) <6106b1f2b0b303b06ae476253dbb5f3f> /usr/lib/libstdc++.6.dylib
0x94e5b000 - 0x94e86fe7 libauto.dylib ??? (???) <2072d673706bbe463ed2426af57a28d7> /usr/lib/libauto.dylib
0x94f89000 - 0x94fa4ffb libPng.dylib ??? (???) <4780e979d35aa5ec2cea22678836cea5> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ImageIO.framework/Versions/A/Resources/libPng.dylib
0x94fd0000 - 0x950f4fe3 com.apple.audio.toolbox.AudioToolbox 1.5.1 (1.5.1) /System/Library/Frameworks/AudioToolbox.framework/Versions/A/AudioToolbox
0x95275000 - 0x95685fef libBLAS.dylib ??? (???) /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libBLAS.dylib
0x95686000 - 0x95689fff com.apple.help 1.1 (36) <175489f8adf287b3ebd259362b0292c0> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/Help.framework/Versions/A/Help
0x95741000 - 0x95748ff7 libCGATS.A.dylib ??? (???) <973c01cc14f3d673270e269ccfaec660> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/CoreGraphics.framework/Versions/A/Resources/libCGATS.A.dylib
0x95753000 - 0x957acff7 libGLU.dylib ??? (???) /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGLU.dylib
0x957e2000 - 0x959b0fff com.apple.security 5.0.4 (34102) <f01d6cbd6a0f24f6c13952ed448e77d6> /System/Library/Frameworks/Security.framework/Versions/A/Security
0x959b1000 - 0x95c8bff3 com.apple.CoreServices.CarbonCore 786.6 (786.6) <5682aae1e2cf5ae750d5a4dea98c084c> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/CarbonCore.framework/Versions/A/CarbonCore
0x95ca4000 - 0x95ca4ffd com.apple.vecLib 3.4.2 (vecLib 3.4.2) /System/Library/Frameworks/vecLib.framework/Versions/A/vecLib
0x95ca5000 - 0x95d4cfeb com.apple.QD 3.11.54 (???) <b743398c24c38e581a86e91744a2ba6e> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/QD.framework/Versions/A/QD
0x95d4d000 - 0x95d7cfe3 com.apple.AE 402.2 (402.2) <d0da935e781446faa4563e7a9c587cce> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/AE.framework/Versions/A/AE
0x95dcd000 - 0x95e49feb com.apple.audio.CoreAudio 3.1.0 (3.1) <be7120e91df91425e904d5327b4338b7> /System/Library/Frameworks/CoreAudio.framework/Versions/A/CoreAudio
0x95e50000 - 0x95f96ff7 com.apple.ImageIO.framework 2.0.4 (2.0.4) <6a6623d3d1a7292b5c3763dcd108b55f> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ImageIO.framework/Versions/A/ImageIO
0x95f97000 - 0x95fa0fff com.apple.speech.recognition.framework 3.7.24 (3.7.24) <6a6518b392d3d41ace3dcea69d6809d9> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/SpeechRecognition.framework/Versions/A/SpeechRecognition
0x95fa1000 - 0x9635ffea libLAPACK.dylib ??? (???) /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libLAPACK.dylib
0x96372000 - 0x964d2ff3 libSystem.B.dylib ??? (???) <a12f397abf2285077b89bd726bff5b18> /usr/lib/libSystem.B.dylib
0x96503000 - 0x965cbfef com.apple.WebKit 5528 (5528.1) <fc969bc7b1dbf67d61eaea8afe646865> /System/Library/Frameworks/WebKit.framework/Versions/A/WebKit
0x965cc000 - 0x9667effb libcrypto.0.9.7.dylib ??? (???) <69bc2457aa23f12fa7d052601d48fa29> /usr/lib/libcrypto.0.9.7.dylib
0x9667f000 - 0x96986fff com.apple.HIToolbox 1.5.4 (???) <5e2af960b53059c648af4adb99471032> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/HIToolbox.framework/Versions/A/HIToolbox
0x96987000 - 0x97184fef com.apple.AppKit 6.5.3 (949.34) <4c7af9b12c894d4a528fda29377f143b> /System/Library/Frameworks/AppKit.framework/Versions/C/AppKit
0x97185000 - 0x971a4ffa libJPEG.dylib ??? (???) <e7eb56555109e23144924cd64aa8daec> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ImageIO.framework/Versions/A/Resources/libJPEG.dylib
0x971a5000 - 0x97270fff com.apple.ColorSync 4.5.1 (4.5.1) /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ColorSync.framework/Versions/A/ColorSync
0x97271000 - 0x97285ff3 com.apple.ImageCapture 4.0 (5.0.0) /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/ImageCapture.framework/Versions/A/ImageCapture
0x972da000 - 0x972defff libmathCommon.A.dylib ??? (???) /usr/lib/system/libmathCommon.A.dylib
0x972fc000 - 0x9733dfe7 libRIP.A.dylib ??? (???) <1f09316e876fe813271bdfb9eb5b229e> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/CoreGraphics.framework/Versions/A/Resources/libRIP.A.dylib
0x973d8000 - 0x973fcfff libxslt.1.dylib ??? (???) <ea5c8d349a3934ecc2b936f9cdfaba04> /usr/lib/libxslt.1.dylib
0x973fd000 - 0x973fdff8 com.apple.Cocoa 6.5 (???) <e9318c93615b27231498bbe585b8da98> /System/Library/Frameworks/Cocoa.framework/Versions/A/Cocoa
0x973fe000 - 0x9740effc com.apple.LangAnalysis 1.6.4 (1.6.4) <8b7831b5f74a950a56cf2d22a2d436f6> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/LangAnalysis.framework/Versions/A/LangAnalysis
0x97434000 - 0x974b3ff5 com.apple.SearchKit 1.2.1 (1.2.1) <3140a605db2abf56b237fa156a08b28b> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/SearchKit.framework/Versions/A/SearchKit
0xfffe8000 - 0xfffebfff libobjc.A.dylib ??? (???) /usr/lib/libobjc.A.dylib
0xffff0000 - 0xffff1780 libSystem.B.dylib ??? (???) /usr/lib/libSystem.B.dylib
xgman
Post by xgman » Sat Nov 15, 2008 9:02 pm
Another try:
Process: Audacity [1277]
Path: /Applications/MUTIMEDIA/Audacity/Audacity.app/Contents/MacOS/Audacity
Version: 1.2.5 (1.2.5)
Date/Time: 2008-11-15 16:00:52.465 -0500
Report Version: 6
Exception Type: EXC_BAD_ACCESS (SIGSEGV)
Exception Codes: KERN_INVALID_ADDRESS at 0x0000000040fd6000
Crashed Thread: 0
Thread 0 Crashed:
0 ??? 0x2afc6005 0 + 721182725
1 com.apple.CoreFoundation 0x926bbcf8 CFRunLoopRunInMode + 88
2 com.apple.HIToolbox 0x966ae480 RunCurrentEventLoopInMode + 283
3 com.apple.HIToolbox 0x967619c4 GetNextEventMatchingMask + 100
4 com.apple.HIToolbox 0x96761826 WNEInternal + 151
5 com.apple.HIToolbox 0x96761785 WaitNextEvent + 54
6 net.sourceforge.audacity 0x002d5bca 0x1000 + 2968522
7 net.sourceforge.audacity 0x002d5ce5 0x1000 + 2968805
8 net.sourceforge.audacity 0x002d5720 0x1000 + 2967328
9 net.sourceforge.audacity 0x0000de46 0x1000 + 52806
10 net.sourceforge.audacity 0x00002716 0x1000 + 5910
11 net.sourceforge.audacity 0x00002631 0x1000 + 5681
Post by kozikowski » Sun Nov 16, 2008 1:16 am
<<<This is driving me nuts!>>>
Unfortunately, it's only driving you nuts. If it was driving two or three thousand people nuts, it would bubble up to the top of the attention pile--like that Noise Reduction in 1.3.6 thing. Everybody has that problem.
Even if a developer were to show up, they are most likely to tell you to reduce your machine to the state it was in when it came out of the box. No external sound devices and no foreign drivers. You do that if trashing your .cfg file fails.
xgman
Post by xgman » Mon Nov 17, 2008 5:46 pm
Well, thanks for the help. I guess I'll try a different program like amadeus pro, as Audacity seems to be the only one that I have problems with, so not to reinvent the wheel just to use that one and I get that it is free and all, but oh well. . . . . .
