Having a problem recording stereo mix(SOLVED).
waxcylinder
Re: Having a problem recording stereo mix(SOLVED).
Post by waxcylinder » Fri Apr 12, 2013 4:30 pm
Gale Andrews wrote:
wizarddrummer wrote:Is there a way to mark a post Solved other than putting it into the subject?
No, but if we find a way to do it, I agree it would be nice to do this with a button. ;)
+1 great idea (it would be good if that auto-locked the topic too)
