registry error with Mac version
Help for Audacity on macOS.
de073823
Post by de073823 » Wed Apr 03, 2013 8:30 am
Any ideas I get a registry error on loading Audacity;
I Ok out of the error box & things run normally
I am not running any Windows emulation
OSX 10.8 & Audacity 2.03
Thanks
Dave
Re: registry error with Mac version
Post by kozikowski » Wed Apr 03, 2013 4:33 pm
What's the computer?
Did you get the right Audacity?
http://audacityteam.org/download/mac
de073823
Post by de073823 » Wed Apr 03, 2013 6:03 pm
Mac is i5 iMac 27 inch, Audacity is 2.03
Program works fine it just this startup error which seems weird
Dave
Post by Gale Andrews » Wed Apr 03, 2013 11:19 pm
We don't know what the "registry error" is.
Please post an image of this error. Command - Shift - 3 to capture the screen. Find the image on your Desktop and attach it here - see http://forum.audacityteam.org/viewtopic ... 49&t=64936 for how to attach images.
de073823
Post by de073823 » Thu Apr 04, 2013 10:29 am
Attached error via screen capture
Dave
screen capture of error
Screen Shot 2013-04-04 at 11.21.38.png (34.14 KiB) Viewed 987 times
Post by Gale Andrews » Fri Apr 05, 2013 7:41 am
de073823 wrote:Attached error via screen capture
Thanks.
It is not an Audacity error (not in our source code).
I suspect it is the remains of some audio plug-in that you did not completely uninstall, probably an Audio Unit or VST. Please see here: http://manual.audacityteam.org/o/man/ef ... ST_Effects and on to the end of the page for the locations from which Audacity loads VST and Audio Unit plug-ins.
