Equalization preview not playing at correct volume
Paul L
Post by Paul L » Wed Apr 03, 2013 3:06 am
Observed in 2.0.3 compared with 2.0.2 on Windows 7:
The "Preview" button, at least for Equalization, no longer seems to play exactly what I get after applying the effect, but rather, seems to play it louder. I never noticed that with 2.0.2. Don't know about the other effects which I use less often.
Re: Equalization preview not playing at correct volume
Post by Gale Andrews » Wed Apr 03, 2013 5:45 am
Thanks for the report. I don't hear an obvious problem with Draw Curves. Might this be connected with http://forum.audacityteam.org/viewtopic ... 50&t=71512 ?
Paul L
Post by Paul L » Wed Apr 03, 2013 5:54 am
I don't know. Do you mean to say that you do hear it with graphic equalization?
Post by Gale Andrews » Wed Apr 03, 2013 6:00 am
Paul L wrote:I don't know. Do you mean to say that you do hear it with graphic equalization?
No I don't hear it there either.
Could you give steps to reproduce it in Draw Curves?
