dB definition in help
Feedback and Reviews for Audacity 2.x
This board is ONLY for general feedback and discussion about Audacity 2.X.
If you require help, or think you have found a "bug", please post on the forum board relevant to your operating system.
lord
Post by lord » Wed Apr 03, 2013 1:22 am
The definition of dB is incorrectly documented. In the documentation, decibels are confused with bels. A change of 10 dB is a factor of 10, a change of 20 dB is a factor of 100, etc..
It would be good to know if simply the documentation is incorrect or the application's labels of the values used as well.
Re: dB definition in help
Post by kozikowski » Wed Apr 03, 2013 1:46 am
Can you give us a hint? There's a lot of documentation out there.
lord
Post by lord » Wed Apr 03, 2013 6:43 am
Sorry, I should have specified
I refer to the discussion below. best regards
-SL
http://wiki.audacityteam.org/index.php? ... aveform_dB
HowAudacityWorks
Waveform dB
Q: How is the waveform dB calculated?
A: See Wikipedia for full details. The basic idea is that dB is a logarithmic scale. If the sound amplitude (air pressure) goes up by a factor of 10 the dB goes up by one point. If it increases 100-fold then in dB it goes up by 2 and so on. This is very like the Richter scale for earthquakes. A one point change is a 10-fold increase in pressure.
Post by Gale Andrews » Wed Apr 03, 2013 8:08 am
An Audacity developer wrote that Wiki answer, but I am confused by it.
lord wrote:A change of 10 dB is a factor of 10, a change of 20 dB is a factor of 100, etc..
That's the power ratio, though. Audacity uses amplitude ratio, so a change of 10 dB is a factor of about 3, and a change of 20 dB is a factor of 10.
Robert J. H.
Post by Robert J. H. » Wed Apr 03, 2013 8:15 am
Yes, that is certainly faulty.
It isn't even true for Bel, since we are dealing with amplitudes and those are doubled by 6 dB and 10-fold by 20 dB. Or in linear terms: 0 dB = 1 and -20 dB is 0.1.
Post by Gale Andrews » Thu Apr 04, 2013 7:31 am
OK I attempted a "repair":
http://wiki.audacityteam.org/wiki/HowAu ... aveform_dB .
Thanks for the initial report.
Robert J. H.
Post by Robert J. H. » Thu Apr 04, 2013 9:29 am
Thank you Gayle for the correction.
