Crash on joining split tracks
asbestos bill
Post by asbestos bill » Tue Apr 02, 2013 6:29 pm
There's probably already a thread about this, but I'm unsure of the terminology, which makes searching for it difficult.
Let's say you put the cursor in the middle of a track and split it with Ctrl+I. You can then merge it back together by clicking on the seam. For a long time (i.e., many versions of Audacity), clicking on splits has been very dangerous, and I've learned to save beforehand and be very deliberate in how I click on them. No sudden movement, don't make eye contact, etc. I thought the issue had been resolved in v2, but just the other day I clicked and it thought for a while, gave me the spinning ring, then notified me that Audacity had stopped working. Whenever this happens, I recover the project, click on the same split, and it works fine. ...But I'd rather not waste the time recovering (I work with movie length files).
I'm on Windows 7, 64bit, and Audacity 2.0.3
Re: Crash on joining split tracks
Post by Gale Andrews » Wed Apr 03, 2013 4:57 am
asbestos bill wrote:Let's say you put the cursor in the middle of a track and split it with Ctrl+I. You can then merge it back together by clicking on the seam. For a long time (i.e., many versions of Audacity), clicking on splits has been very dangerous, and I've learned to save beforehand and be very deliberate in how I click on them. No sudden movement, don't make eye contact, etc. I thought the issue had been resolved in v2, but just the other day I clicked and it thought for a while, gave me the spinning ring, then notified me that Audacity had stopped working. Whenever this happens, I recover the project, click on the same split, and it works fine. ...But I'd rather not waste the time recovering (I work with movie length files).
Thanks for the report.
Clicking at split lines usually causes crash problems because there is actually a hidden clip comprising a single audio sample at a point close to the real split line. You cannot see both clips until you zoom in far enough to see all the individual sample dots.
The best suggestion I have is that the next time you experience this crash, please before reopening Audacity:
  1. Show hidden files and folders:
    http://windows.microsoft.com/en-us/wind ... dden-files .
  2. Go to Users<your user name>AppDataRoamingAudacity AutoSave
  3. Make a copy of the "autosave" file and attach it to your post .
  4. Recover the project when you reopen Audacity and save it as a new project name (File > Save Project As...).
We can then see at that time if it is useful or possible to obtain the project file and _data folder from you (the _data folder is very large, of course, especially if you have movie-length files).
Note that you can merge by selecting over the split line then CTRL + J. I think there is some evidence that this method does not usually create a crash.
asbestos bill
Post by asbestos bill » Thu Apr 04, 2013 3:44 pm
Thanks a bunch. Ctrl+J can even do multiple splits at once; that's fantastic...
