High Pass Filter disappeared
[email protected]
The High Pass Filter in Effects disappeared. I now see Apple: AUHipass, but it does not work the same. How do I find the High Pass Filter again?
Re: High Pass Filter disappeared
Do you have all the rest of the tools and filters like this:
- Attachments
- Screen Shot 2013-04-01 at 8.29.11 AM.png (43.39 KiB) Viewed 1308 times
[email protected]
Under Effects, nothing below Apple: RoundTripAAC. (using Mac OS X, v 10.8.2, Audacity v 1.3.13-beta unicode). Someone suggested I un-install and re-install.
[email protected]
Problem solved. I reinstalled. Thanks
The effects below the Apple ones are special, separate files and can go missing. They're not a native part of the program.
