Thanks.
So can we mark this as solved, that it was a driver problem?
It sounds as if Microsoft gave you a generic Realtek driver that is not really matched with your Gateway computer. This is why they were reluctant.
Mixer Toolbar Greyed Out, needed driver[SOLVED]
- Quality Assurance
Re: Mixer Toolbar Greyed Out Win 7 have micosound mapper
Re: Mixer Toolbar Greyed Out, needed driver[SOLVED]
Yes, I am still struggling with burning & completing the last 2 steps. I read in the manual to only use the generic driver as a last resort.
- Quality Assurance
OK. Thanks for starting a new topic for thatcheckin1 wrote:Yes, I am still struggling with burning & completing the last 2 steps.
