Could Not Open Mp3 Encoding Library
Damienb
Re: Could Not Open Mp3 Encoding Library
Post by Damienb » Sat Apr 06, 2013 10:31 am
Interesting turn of events folks. I put a lot of my VST plugins back into the folder and guess what? Mp3 encoding issue cropped up.
Is there a limit to the number of files in the plugins folder? I currently have 151 items in there. I have done this one by one, scanning for VST each time I open Audacity. Files left that keep causing the MP3 error are the following:
surround_encoder_1401.dll
VoxengoRedunoise.dll
vynil_1905.dll
wave_terrain_1412.dll
xfade_1915.dll
zm1_1428.dll
Seems when I put one or a couple of these into the Plugins folder I get the error. Looking at the dates on some of these dlls, they are 2006 so it's probably time to get rid of them anyway.
Damien
Post by steve » Sat Apr 06, 2013 12:59 pm
Damienb wrote: Is there a limit to the number of files in the plugins folder? I
I don't think so. At one point I had well over 200 plug-ins installed with no problem.
Damienb wrote:I have done this one by one, scanning for VST each time I open Audacity. Files left that keep causing the MP3 error are the following:
vynil_1905.dll
xfade_1915.dll
zm1_1428.dll
Do you know what those dlls are? wave_terrain_1412.dll sounds like a synthesizer.
I think that vynil_1905 may be one of the iZotope effects.
Are you saying that it is only when there is a combination of these effects that the problem happens, or that you have so far narrowed it down to these?
Post by Gale Andrews » Sat Apr 06, 2013 9:24 pm
You should be able to install LAME into the normal Windows Program Files (x86) directory.
Those are the swh LADSPA plug-in set for Windows.
I have tipped all those and another 100 LADSPA plug-ins for Windows into the Audacity "Plug-Ins" folder and I can still export MP3.
The DWI file you sent was for lame_enc.dll 3.98.2 so not the currently recommended version.
If this is still a problem with the recommended LAME can you please send a DWI for that ( http://lame1.buanzo.com.ar/Lame_v3.99.3_for_Windows.exe ) .
Could this be something to do with your building the computer yourself?
Damienb
Post by Damienb » Sat Apr 06, 2013 11:26 pm
steve wrote: I don't think so. At one point I had well over 200 plug-ins installed with no problem.
I didn't think there would be either, mind you 150 is quite plenty for what I need to do! I really should thin them out to the 10-20 most used.
If I put any one of those in (e.g one at a time, open audacity, rescan plugins), I then get the error. These files I have had for a long time and I wonder if they are causing a conflict simply because they are old. Audacity is working fine without them and to be honest, I don't miss these plugins. Probably never used them!
gale wrote:Could this be something to do with your building the computer yourself?
Unlikely. I've been building PC's for years. Am an electronics service tech and A/V tech. PC's these days are plug and play anyway.
gale wrote:The DWI file you sent was for lame_enc.dll 3.98.2 so not the currently recommended version.
That's strange as I was sure I had the latest one on. I had run that DWI before I uninstalled everything. So now on my system is Audacity and that Lame version you linked. I ran DWI but still got the same error of not finding that IESHIMS.dll and that's with Audacity working fine.
I am happy to leave it as is now and just not include those few plugins and put it down to something weird.
Damien
Post by Gale Andrews » Sun Apr 07, 2013 1:10 am
Damien,
The lack of IESHIMS.dll doesn't stop lame_enc.dll working - it's cited in DWI's where lame_enc.dll works fine.
At the point when you add one of those LADSPA plug-ins and this stops lame_enc.dll working, are there any other DLL's in the Audacity plug-ins folder?
Note that rescan is only required for VST plug-ins, even though the scan will see and ignore LADSPA DLL's. You only need to restart Audacity after adding a LADSPA plug-in (like the ones you mentioned with numbers in their name).
If and when you have time and patience, suppose you have only the plug-ins Audacity shipped with (including the three LADSPA DLL's GVerb, Hard Limiter and SC4). Now add one of those plug-ins you mentioned with a number. Restart Audacity but don't rescan. Can you still write an MP3?
Damienb
Post by Damienb » Sun Apr 07, 2013 2:46 am
I may not get to that right away as thats a bit of a time sync and my week is HECTIC! We've had a end of day light savings change today and Im about to start a night shift AV install for three nights :(
I'll put it on my to do list.
Damien
