Joining Mp3 Files...
Help for Audacity on macOS.
dkjlx
Post by dkjlx » Wed Mar 20, 2013 10:16 pm
I searched through the topics but I can't figure this out and it should be very simple.
I need to join four 15 minute mp3 files in to one file. Back to back - no second of space in between or no trying to carefully drag a box next to another box. When I had a PC, this was very simple - I would select files, put them in the order I want and the files would merge/join. Unfortunately, Macs don't have these easy programs - Audacity is the only one I can find and it can't figure out how to do the simple things. Can anyone help? And the Wiki didn't help either.
Reason: Topic moved to Mac OS X forum
Re: Joining Mp3 Files...
Post by kozikowski » Wed Mar 20, 2013 11:57 pm
You're right. I can't do it, either.
I don't believe Windows can do it. What program were you running? Given how sensitive Windows Media is to copy protection, it has to be an outside program.
There was a Feature Request for Import-Paste (I got the words wrong, but you get the idea). I'm not running the latest Audacity, but Audacity 2.0.3 may do that. I need to look.
Post by kozikowski » Thu Mar 21, 2013 12:00 am
dkjlx
Post by dkjlx » Thu Mar 21, 2013 3:17 am
Windows did do this - there are several programs that do it. I am trying to see if Mac can do this with Audacity. I can't seem to figure it out.
Post by steve » Thu Mar 21, 2013 4:53 am
You could import all of the files (File menu > Import >Audio), then use the Time Shift tool to drag the files end to end like this:
When you export the project to create a new file (File menu > Export) they will be automatically mixed together into a single file.
Robert J. H.
Post by Robert J. H. » Thu Mar 21, 2013 6:50 pm
There's alternatively my plug-in kicking about that is intended for such tasks:
http://forum.audacityteam.org/viewtopic ... 9e#p190928
