lost my settings
Help for Audacity on macOS.
Xander
lost my settings
Post by Xander » Sat Mar 16, 2013 3:39 am
Hi! Can someone help me please? I am recording audio tapes from a usb cassette capture device on to a mac running OX 10.8.2. I have successfully done this in the past but today I cannot find the correct settings and no recording. Is there anyway I can reset the default settings? Or can someone tell me how to setup for this type of recording? Thanks Xander
Re: lost my settings
Post by Gale Andrews » Sat Mar 16, 2013 7:16 am
You have got to choose the USB Capture Device as input (recording) device in Audacity. Try this http://wiki.audacityteam.org/wiki/User: ... ut_devices .
You can restore Audacity default settings by following this http://manual.audacityteam.org/o/man/pr ... tml#stored but the default will not be to record from the USB device.
