Distortion only when using Software Playthrough?
Re: Distortion only when using Software Playthrough?
Post by steve » Tue Mar 19, 2013 8:06 am
It's the main thing that's wrong - that's the cause of that nasty crackle. If you put the track on spectrogram view and zoom in on a couple of notes full screen you can match the crackles with the vertical red lines.
