No input jack on new iMAC
Help for Audacity on macOS.
Re: No input jack on new iMAC
Post by steve » Sun Jun 02, 2013 10:03 am
caponsacchi wrote: Previously, I found the quickest, and still satisfactory, solution for recording sound from my computer was a patchcord linking the audio input to the headphones jack on the back of my iMac. I'm wondering if there's any interface that would permit a similar quick and handy way of capturing computer audio.
With the Behringer UCA 202 you can link the (line level) outputs to the (line level) inputs. The headphone socket is still available so you can plug headphone in to listen to what is being recorded.
billw58
Post by billw58 » Sun Jun 02, 2013 1:35 pm
caponsacchi wrote:I'm wondering if there's any interface that would permit a similar quick and handy way of capturing computer audio.
The software solution is Soundflower. Have a look at this page: http://manual.audacityteam.org/man/Tuto ... ack_on_Mac
-- Bill
Post by kozikowski » Sun Jun 02, 2013 4:14 pm
For Mac self-recording, you can use the SoundFlower software.
http://manual.audacityteam.org/o/man/tu ... n_mac.html
You don't need the mechanical patch cords. And yes, the UCA-202 counts as both Stereo Line-In and Stereo Line-Out. It can take the place of the older compatible Mac connections, and it has its own headphone connection.
http://www.kozco.com/tech/audacity/pix/MacLineIn.jpg
http://www.kozco.com/tech/audacity/pix/ ... Lenovo.jpg
The Mac usually adds the UCA202 to the list of audio connections in Apple > System Preferences > Sound. It may not say that. It may say "USB Audo Device" which will be clear unless you have multiple audio devices.
