Can not build audacity 2.0.3 with wxWidgets 2.8.12
Building and customizing Audacity from the source code.
agrbalan
Re: Can not build audacity 2.0.3 with wxWidgets 2.8.12
Post by agrbalan » Mon Mar 18, 2013 1:38 am
Hi Gale,
I hadn't seen before the link you mentioned ( http://audacity.238276.n2.nabble.com/Ti ... l#a7557180 )
I chose the following solution in order to eliminate the MAX_PATH error:
***** Modify Audacity.h
#ifdef __WXMSW__
#include "configwin.h"
#undef PLATFORM_MAX_PATH
#define PLATFORM_MAX_PATH 260 //-------------- only this line has been changed
#endif
I have no other problems compiling Audacity with ASIO now.
I have seen other people with the MAX_PATH error. Maybe it is a good idea to incorporate one of the solutions to the SVN HEAD version.
Audacity is a great software! Thanks for all developers!
Cheers
André
agrbalan
Post by agrbalan » Mon Mar 18, 2013 4:15 am
I would like to add another important observation: When compiling wxWidgets I had to set "wxUSE_ODBC" to 1 in C:wxWidgets-2.8.12includewxmswsetup.h. Then I compile the whole wxWidgets solution in DLL Unicode Release.
Otherwise, I would get errors with the Yield marcro, such as "error C2039: 'Yield' : is not a member of 'wxApp' " while trying to build Audacity
Cheers
André
Post by Gale Andrews » Tue Mar 19, 2013 8:20 am
agrbalan wrote:I would like to add another important observation: When compiling wxWidgets I had to set "wxUSE_ODBC" to 1 in C:wxWidgets-2.8.12includewxmswsetup.h. Then I compile the whole wxWidgets solution in DLL Unicode Release.
Everyone on Audacity Team builds with "wxUSE_ODBC" set to 1, because to enable extra accessibility we replace "wxWidgets-2.8.12includewxmswsetup.h" with the "setup.h" in "audacitywinwxWidgets_additions" which sets "wxUSE_ODBC" to 1. This is as per wincompile.txt ( http://audacity.googlecode.com/svn/auda ... ompile.txt ) .
Did you compile the whole widgets build or only compile the five Widgets solutions recommended in wincompile.txt (namely adv, base, core, html and net)?
