Fixing AVFORMAT not
Keatah
Fixing AVFORMAT not
Post by Keatah » Sat Mar 09, 2013 9:47 am
Can someone tell me in plain english what the avformat not monolithic error is and how to fix it? This is on XP SP3.
03:29:50: Audacity 2.0.3
03:30:01: Trying to load FFmpeg libraries...
03:30:01: mLibAVFormatPath ('C:Program FilesFFmpeg_v0.6.2_for_Audacity_on_Windowsavformat-52.dll') is not empty. Loading from it.
03:30:01: Looking up PATH environment variable...
03:30:01: PATH = 'C:WINDOWSsystem32;C:WINDOWS;C:WINDOWSsystem32wbem;C:Program FilesFFmpeg_v0.6.2_for_Audacity_on_Windows;C:Program FilesGTK2-Runtimelib'
03:30:01: Checking that 'C:Program FilesFFmpeg_v0.6.2_for_Audacity_on_Windows' is in PATH...
03:30:01: FFmpeg directory is in PATH.
03:30:01: Checking for monolithic avformat from 'C:Program FilesFFmpeg_v0.6.2_for_Audacity_on_Windowsavformat-52.dll'.
03:30:01: Error: Couldn't find symbol 'avutil_version' in a dynamic library (error 127: the specified procedure could not be found.)
03:30:01: avformat not monolithic
03:30:01: Loading avutil from 'C:Program FilesFFmpeg_v0.6.2_for_Audacity_on_Windowsavutil-50.dll'.
03:30:01: Loading avcodec from 'C:Program FilesFFmpeg_v0.6.2_for_Audacity_on_Windowsavcodec-52.dll'.
03:30:01: Loading avformat from 'C:Program FilesFFmpeg_v0.6.2_for_Audacity_on_Windowsavformat-52.dll'.
03:30:01: Actual avutil path C:Program FilesFFmpeg_v0.6.2_for_Audacity_on_Windowsavutil-50.dll
03:30:01: Actual avcodec path C:Program FilesFFmpeg_v0.6.2_for_Audacity_on_Windowsavcodec-52.dll
03:30:01: Actual avformat path C:Program FilesFFmpeg_v0.6.2_for_Audacity_on_Windowsavformat-52.dll
03:30:01: Importing symbols...
03:30:01: All symbols loaded successfully. Initializing the library.
03:30:01: Retrieving FFmpeg library version numbers:
03:30:01: AVCodec version 0x344802 - 52.72.2 (built against 0x344802 - 52.72.2)
03:30:01: AVFormat version 0x344002 - 52.64.2 (built against 0x344002 - 52.64.2)
03:30:01: AVUtil version 0x320f01 - 50.15.1 (built against 0x320f01 - 50.15.1)
03:30:01: FFmpeg libraries loaded successfully.
Re: Fixing AVFORMAT not
Post by steve » Sat Mar 09, 2013 1:45 pm
It's not really an "error".
FFMpeg can be built in different ways, monolithic or not monolithic. The "error" is that Audacity is unable to load the monolithic build of FFMpeg (because you don't have it). When that fails, Audacity looks for a non-monolithic build (which you do have) and loads it successfully (as shown in the message "FFmpeg libraries loaded successfully.")
Keatah
Post by Keatah » Sat Mar 09, 2013 7:11 pm
very good.
