waxcylinder wrote:If you want to just use WMP (and not iTunes) then you will probably have to export MP3s from Audacity for use there - unless you have massive storage space and want to use uncompressed WAVs.
Tape Cassette Player/bought through Magazine/Audacity Format
Re: Tape Cassette Player/bought through Magazine/Audacity Fo
Waxycylinder, hi... And thank you... Understand this last post of yours; but, need to know how to download this one 'dll', in question? Do I reinstall the original 'Audacity' to obtain this 'dll'; or is there another newer download for Audacity? That would be better? Can you advise, or give me a link on this particular 'dll'. As the 'Error' message said, that this in fact, is all I need to download (Transfer) these 'Taped' segments, over to an 'MP3' format, to be accepted by 'WMP'. Thanks, Derek
Look in the Audacity "Help menu > About Audacity". If your version is not Audacity 2.0.3, uninstall it and install Audacity 2.0.3 which you can get here: http://audacityteam.org/download/windows (use the recommended installer).Derek2012 wrote:Do I reinstall the original 'Audacity' to obtain this 'dll'; or is there another newer download for Audacity?
For exporting in MP3 format, see here for instructions to download and install LAME: http://manual.audacityteam.org/o/man/fa ... .html#lame
