Here goes Something or maby Nothing, I took me 4 (FOUR) hours to write this. Thank God for COPY & PASTE
I don't even know where to start???? ( " RAIN CHECK"[KOZ])
1. ( [KOZ]What you probably want is Export to WAV)
I do want to do this, but don't I have to do all my EDITING first? Are you saying I can save files to WAV?
and EDIT later?
Without saving it in thr AUDACITY Program?
2. I do have the settings you specified:
Audio I/O, Recording, 2-channel stereo.
Quality, 44100 Hz, 16 Bit.(should this be set higher? If so what setting do you reccomend?)
3. ([KOZ]Windows Audio Files, piano.wav for example, are excellent quality)
are you talking about WMP10 WAV files?
4. I have several CD burning programs, I use
Pinnacle the most but I have NERO, WMP10 and probebly some i don't even know I have. Media Player Classic that comes with K-LITE CODEC pack may have a burner but I don't know.
5. ([KOZ]Each music selection should be saved as one .WAV file so you can skip and select tracks in the CD)
All I want to do is transfer the music from the Vinyl and burn a whole vinyl album to one .wav file, and then to a CD. Right now I only have 1 side in the AUDACITY program, I want to do the other side, and many,many more.
QUESTION: should each side of the Record be a seperate AUDACITY program. If I am able to get the files burned to a CD, I will then select files from the CD to RIP into WMP10.
When i select "Export as WAVE" from the "FILE" menu, WHAT happens?
Do I have to have a place ready to put the exported files in?
Sorry about this BOOK. I tried to stick to your " RAIN CHECK" plus some things I wanted to ask. I hope I don't BURN you out on ME????
YOU HAVE A NICE DAY!!!
